03-20-2019, 08:56 AM | #1 |
Active Member
3.42 ratio rearend
Want to change rearend in my truck. Have 7000r4 tone know where I might find a 3.42
Rearend close to Effingham, Illinois.. |
03-20-2019, 11:01 AM | #2 |
Re: 3.42 ratio rearend
Soooo...what rear do we have? why not just change the gears
03-20-2019, 01:30 PM | #3 |
I would recommend a 3.73 ratio with the 700R4.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
03-20-2019, 01:38 PM | #4 |
Agreed, minimum 3.73.
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires 04' GMC Yukon XL, 3/4 ton, 8.1L |
03-20-2019, 01:48 PM | #5 |
Post Whore
i also agree with Keith...3.73s....but also ,what size tires are you running?
03-20-2019, 09:03 PM | #6 |
Spudder, 3.42 and 700R4 may result in too low of rpm at lower highway speeds - lugging would be possible. What diameter tire do/will you have and what’s your current rear gearing? 3.73 really is the sweet spot for an o/d trans. Even a 4.10 is probably preferable to 3.42 unless you’re trying to break a land speed record. But agree with all the above folks - there’s a reason GM put 3.73s in the vast majority of their 1/2 tons in the 90s and 2000s.
03-20-2019, 09:52 PM | #7 |
Mine 87 has a 5.7, 700, with 3.42 ratio running 235/75/r15 tires.
It depends on what you use the truck for. Most of the time I am putting along coasting a majority of the time with next to no rpms. But I can always drop the thing into direct and drive that way. If your towing 3.42 gears come in handy by not using overdrive unless your on flat ground. Run around 2500 at 65mph in direct. Which is about as much wind as I want to push. That being said they came with the truck and I am only running 30" tires. Bigger tires require more gear.
1991 Metro commuter 1991 s10 future project truck 1987 V10 backup daily/junk truck 1985 K20 Winter beater 1991 R30(squarebody) c/c flatbed towrig 1994 s10 80"wb custom build |
03-20-2019, 10:31 PM | #8 |
My ‘87 4x4 came with 3.42’s and 700r4 also. I ran 31” tires with that combo. I would have preferred 3.73’s, but the 3.42’s did fine.
03-21-2019, 09:05 AM | #9 |
Active Member
Thanks guys for your replies. I have had several trucks with 3.42 gears and always liked that gear. Never ran oversized tires. I now have two later 2 door Tahoes, one with 3.42 and the other with 3.73. I like both of them!
Have a project '64 pickup with a 700R4 and want to use a square body rearend in it. Just got home from Arkansas and could not find any square body 3.42 or 3.73 rears. Can't believe how the stuff has dried up! I think I need a rearend out of a '83 to '87 C10 or '83 to '91 in Suburban with 700R4. Any help locating a rearend close to home would be appreciated. |
