![]() Join Date: Jul 2016
71-2 auto steering column, black, serviced and painted (another one)
Completely disassembled, cleaned, bead blasted and then primed and painted gloss black. Bearings, shift collar and shift detents cleaned and lubed, then set to factory spec.
Turn signal switch disassembled, contacts polished then lubed and re-assembled. $200 shipped. |
Re: 71-2 auto steering column, black, serviced and painted (another one)
To the top
Active Member
![]() Join Date: Feb 2019
ill take it, Ive got a non tilt auto column i can sell as well it has a different plug (flat) ive got a 72 will this be plug n play?
#4 | |
I will send you a PM about your column. |
Active Member
I’m switching from 3 on tree column to auto column with a 700r4 what do I do about reverse lights and neutral safety switch?
#6 | |
Neutral safety - find the purple wire from the key inside the wiring harness near the column and interrupt it with the neutral safety switch on the automatic column. |
