03-22-2019, 01:09 PM | #1 |
66 C10 Entropy Radiator with Vintage Air Installation - Help Please
Looking for suggestions on how to run the Electric Fan Relay
Hoping someone else has ran this setup Last edited by Afirehawk1; 03-22-2019 at 04:51 PM. |
03-22-2019, 08:18 PM | #2 |
Re: 66 C10 Entropy Radiator with Vintage Air Installation
Any help out there?
03-23-2019, 12:03 AM | #3 |
60-66 Nut
Depending on the length of the wires, I would mount it on the drivers side of the radiator support, either on the engine side or on the front side where the triangular covers will hide it.
03-23-2019, 09:24 AM | #4 |
It's Better With Nitro
I don't have that exact type of relay you have, but I did mount my relays as Captainfab mentioned on the driver side of the radiator support. You can see my pair of headlight relays just to the right of the radiator opening, and I have a similar set of relays for my fans on the engine bay side of the support.
03-23-2019, 11:12 AM | #5 |
Good ideas
Thanks |
