Old 03-22-2019, 04:21 PM   #1
SunSoaked
SunSoaked's Avatar
Brake bleeding, waste of time?
Is it a waste of time to bleed the front brakes if one had only cracked the rear? I've always conformed to the old rule of start with the farthest wheel and work forward. However, on a split system (such as my 85) I don't see why I need to mess with the fronts if all I did was replace the rear hose.
What say you?
SunSoaked is offline   Reply With Quote
Old 03-22-2019, 05:11 PM   #2
EVRLET
EVRLET's Avatar
Re: Brake bleeding, waste of time?
Yes, I agree it’s a waste of time. The design of a dual master cylinder is just that, one chamber will remain intact in the event you lose front or rear brakes. There are a lot of theories out there about two cylinders but one piston, one will bleed to the other, and whatever else people say.
The best way to know is to do as you said with bleeding only the rears and test the brakes.
Customization is what you want it to look like -- not what other people think it should look like
EVRLET is online now   Reply With Quote
Old 07-23-2019, 06:50 AM   #3
mike16
when was the last time you flushed the system out.
mike16 is offline   Reply With Quote
Old 07-23-2019, 07:31 AM   #4
rpmerf
rpmerf's Avatar
I've often heard you should change your fluid every 3 years or so. Unless you've been in there recently, it might be a good idea, just to get some new fluid through there.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
