03-22-2019, 09:22 PM | #1 | |
Door Top Seals - Yes/No?
So, we are having a debate at the moment, as to whether or not the '73-'74 Squares used a Top Seal on the doors.
My '74 didn't have any when I purchased it used. . . Some suppliers sell them for the '74 and some do not. . . I looked at a pair of replacement doors to buy for future needs and they had the seals. . . So I say they were supposed to be on the truck and maybe mine were removed at some point for some reason. Why else would manufacturers make them for a '74 if they were not supposed to be used? Quote:
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...d.php?t=655783 --Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...ghlight=Belair "Life is tough - wear a cup!" "Old Enough to Know Better - Too Young to Resist" "Junk is something you will need three weeks after you throw it away." |
03-22-2019, 09:31 PM | #2 |
Re: Door Top Seals - Yes/No?
GM did stop using them at some point. Cost down, would have been the reason. But since the doors are the same, from 73-87, they can be installed. I have some for my 86.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
03-22-2019, 10:44 PM | #3 |
MOTORHEAD!
I thought they were a 73 thing because of the lack of drip rail?
82 GMC High Sierra VortecPro 496 12 Bolt, 3.42's AFR 265 Holley 850 Performer RPM Air Gap Hooker 2455's TCI Turbo 400 Super Street Fighter TRRC 12 Bolt Eaton Posi Mark Williams Axles Cal-Tracs Hoosier 30x10.5 Radial Slick Full weight long box pickup Current best- 11.33@117mph |
03-23-2019, 07:01 AM | #4 |
More of a wind noise thing.
03-23-2019, 08:33 AM | #5 |
03-23-2019, 05:12 PM | #6 |
The only ones I have found are glue in only. Not sure but the screw in style "might" just need a screw hole drilled/tapped in the door frame. Even if they are "molded" rather than a continuous roll, I can't see where it would be an issue since the doors are the same profile.
03-23-2019, 08:31 PM | #7 | |
Update: I forgot that I had pics of them, with the part numbers, for Presicion.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR Last edited by TKCR; 03-24-2019 at 08:52 AM. |
03-23-2019, 11:08 PM | #8 |
I thiink I remember Keith posting that these extra seals were used when customers complained about wind noise, or when the automotive press were getting a vehicle for a test drive. I will be getting them for my 83. I have good door seals and drip rails but the passenger door leaks like a sieve when the wind is blowing in a particular direction.
03-24-2019, 04:11 PM | #9 | |
And then, immediately after that when management asked for cost reduction ideas they were the first thing to go. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
03-24-2019, 04:40 PM | #10 |
Thanks Keith. The memory is the second thing to go. I forgot what the first thing is.
03-24-2019, 05:38 PM | #11 |
03-25-2019, 11:43 AM | #12 |
Back in the day my 80 had wind noise at the tops of the doors, I assumed it was normal. In 84 I purchased a new truck and was impressed it was so much quieter. Then I noticed it had an extra seal at the top which the 80 did not have, I inquired at GM and they were available and were glue on, and had I known I could have installed them on my 80 if I still had it.
04-03-2019, 06:23 PM | #13 |
So, got the upper door seals from Precision and I have a question:
Based on the photo below, and assuming the flat part is the bottom of the seal, which side (short or tall) goes against the door frame and which side faces the cab? Also, how far down each side of the door should the seal go? These are not screw on, so I don't have any reference to work with. Dave
04-03-2019, 11:11 PM | #14 |
Subscribed! Because I can see daylight between my upper door frame and cab. Woohoo!
04-04-2019, 04:36 AM | #15 |
TKCR, I justbsearched your part number on precision site and found this: https://www.prp.com/product/detail/1...l=C10&type=All
Their picture looks like the ends do not have the screw on ends. How long ago did you order those?
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project |
04-04-2019, 09:58 AM | #16 | |
04-04-2019, 10:07 AM | #17 |
Is there an advantage to one style over the other? I have the stick on ones on my truck. They work pretty good, i do still get some wind noise through the doors though. Seems I'm getting some noise through the actual door vents.
04-04-2019, 10:19 AM | #18 |
The one without the metal tabs, I believe is just a generic seal. The one with the metal tab, is like the original door seal, that was on the early model trucks.
04-04-2019, 10:39 AM | #19 |
Are there any pictures of the "bolt on" type installed? I'm curious how/where it mounts.
04-04-2019, 10:57 AM | #20 | |
http://67-72chevytrucks.com/vboard/s...6&postcount=20
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR Last edited by TKCR; 04-04-2019 at 11:12 AM. |
04-04-2019, 10:57 AM | #21 | |
I will also say this is a 2 man job. The adhesives are supposed to be allowed to set up a bit so I did the whole strip at once. It gets messy and sticky. You need one person just holding the free end up out of the way as the other applies the seal to the door.
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ) 2001 GMC Sierra K2500 |
04-04-2019, 11:12 AM | #22 |
I put them on my 81 due to some slight water leakage and air noise. I didn't realize they were not used on every year. I have aftermarket doors, that proably would seal better with some adjustments, but I put these on and it seems to solve most of my problems for now. I'll get around to the door adjustments eventually.
This is the driver's door. I just followed the pictures in LMC catalog and the service manual, drilled 2 holes for the anchor screws, then added the gasket sealer to hold them in place.
04-04-2019, 02:52 PM | #23 |
Thanks for the confirmation! I was test fitting to determine starting points and it was apparent that once the glue was on, it could become problematic quite rapidly!
04-04-2019, 02:55 PM | #24 | |
Always good to make sure when using adhesive!
04-04-2019, 04:12 PM | #25 |
Here are some photos from an extra door I have (from a 79 Blazer) that already had this seal on it.
