03-23-2019, 04:15 PM | #1 |
K10 Rear Drive shaft Question
I have the rear driveshaft that has the smaller end that adjust in and out like the front, but does it mount like the front with the smaller end at the diff or the smaller end at the Transfer case.
I removed it long ago and forgot which side went where. Thanks 18Z Last edited by 18Z; 03-23-2019 at 04:21 PM. |
03-23-2019, 04:23 PM | #2 |
Post Whore
Re: K10 Rear Drive shaft Question
The end of the drive line with the small end should be forward.
2wd photo but the idea is the same.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 03-23-2019 at 04:26 PM. Reason: photo I'd. |
03-23-2019, 04:24 PM | #3 |
My K20 has the spline toward the transfer case
At least that how it came to me Someone please chim in if thats incorrect Edit I do not have a carrier bearing Just 1 shaft Last edited by Mts67C10K20; 03-23-2019 at 04:27 PM. Reason: New info |
03-23-2019, 04:42 PM | #4 |
Thanks for the help I will put the small end with splines toward the T-case.
18Z |
03-23-2019, 08:43 PM | #5 |
All about them K’s
Yep, slip joint on the transfer case.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
