Old 11-26-2003, 02:42 AM   #1
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
Angry fron wheel bearing is toast.....
Don't know how long it's been that way, but I checked it out about a week ago when adjusting the brakes and noticed the pass side hub was loose, so I tightened it and such. well, I was checking the bar that connects to the lidler arm off of the chasis today....It seemed loose...wasn't, but i noticed the wheel had lot of wibble-wobble. So I checked the hub and I found lots of shaveings, removed it and found dark sticky grease and the race on the hub was loose, so I gotta get it fixed. Which sucks cause I expected to go home for the break in my truck....now I gotta catch aride with my girl.
I HAVE SOME Q'S...
Do I need to worry about the condition of the spindle. It looks clean and smooth.
The hub will be replaced from my parts truck, or can I buy the race and get it pressed in???
The grease on the bearing is very dark, stiff and full of shavings...is the bearing salvagable???? Either way I'm gonna get a new one.
I cleaned, greased and replaced bearings...I've never done the race in the hub.
Thanks Guys!!!!
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 11-26-2003, 02:59 PM   #2
jhow66
jhow66's Avatar
spindle--ok if smooth
hub-use one off parts truck(loose race means it has spun in hub-new race will not be tight either)
bearings-get new ones --there is slots in hubs to drive out old races-use old race to drive in new ones-make sure they bottom against shoulder.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
