Can't Figure Out What's Wrong With My Gas Gauge
I have read every gas gauge thread that I could find, but I am still having trouble figuring out what is wrong with my gas gauge. The gauge reads approx. 1/3 tank when FULL. The needle will go down as the level in the tank gets lower...all the way to empty.
I have checked continuity on my sending unit wire and it is fine. I have checked the resistance of the sending unit and various gas levels in the tank. I know its supposed to be a 0-90 ohm scale, but I topped off the tank and it was reading 100 ohms?? Could be my cheap multimeter...not sure I pulled the fuel gauge out of the cluster and tested the resistance across each stud and compared this to the readings given in this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=640615 My readings are shown in the picture below (sorry for bad diagram) The other pictures are from the thread listed above I also pulled the resistor off the back of the gauge and tried to check resistance, but I was unable to get a reading. Does this mean the resistor is bad? The previous owner installed two saddle tanks on the truck and I don't know if they are wired into the gas gauge somehow. I don't believe they are because the wiring on the back of the gauge/cluster looks untouched. Both saddle tanks are currently bypassed and the electric transfer pump is completely disconnected. Where do I start? |
Who Changed This?
![]() Join Date: Jan 2013
Re: Can't Figure Out What's Wrong With My Gas Gauge
Don't know what the resistances are supposed to be, but you could have a heavy float. My brass float sprung a leak and was half full (or so) with fuel, so it was hanging low. I put in a plastic float from a sender that I was going to use in my '68 Buick, but I ended up putting a '69 tank in it that had a recirc line. I then had to bend the arm a little to get it to read correctly. When it says "Empty", I have about 2 gallons left, which is good enough for me.
#3 | |
I pulled the sending unit out of the tank and confirmed that it is working properly and the float does not have a leak. Any ideas on what might be the issue here? I am leaning towards resistor...
Workin to live...
Check your grounds
Jason |
![]() Join Date: Nov 2018
#8 | |
I cleaned up the cab to frame ground and checked continuity, its fine. I checked the ground just below the cluster under the dash and that is fine. I also loosened the tank to cab bolts and tightened them back up. Still the same reading. |
#9 | |
The Older Generation
Also make sure there is a ground strap from the engine to the frame. LockDoc
#10 | |
You might take the drivers side sill plate off and make sure that the wires are not bad under it. It is a fairly common problem. Have you removed the wire from the sending unit and grounded it to the tank? This was posted in a thread by member VetteVet: Quote:
#11 | |
#12 | |
#13 |
I installed a new (used) resistor on the gauge and it works as it should now. I also replaced my ground going from the battery to the passenger side fender and I installed a ground from the engine block to the frame for good measure.
#14 |
![]() Join Date: Feb 2009
Same symptoms in my C20, was told it's probably the resister. When the gauge shows an 1/8th of a tank I stop for another $20-30. 1/8th tank is more like a 1/4 or so. No intentions of fixing it either, I just like to drive it. No heat, no A/C, rust. If I'm lucky the windshield wipers work, other times just takes a boost
![]() I saw it read right, once ![]()
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#15 | |
Yeah I would do the same thing when mine got to 1/8 tank. It wasn't much of a problem because you still know approximately how much fuel you have left, but it started annoying me so I decided to fix it. |
#16 |
I bought a used cluster with tach. The fuel gauge in it would only show a quarter or less. I had to use my other gauge. I already have a new sending unit. I could tell when it was low also as when it got near the empty Mark it was low.
1972 c10 cheyenne. 383 stroker 10-1 280 magnum comp cams 700r4 tranny. |
