![]() Join Date: Nov 2018
He341 turbos
Sold!!!
I’ve got one he341 holset turbo left. Factory for a 5.9 24v Cummins. Was on my truck before I went one size larger. Does have some shaft play but not enough for the blades to touch the compressor or exhaust housings. The pictures I’m posting are of the used one I Already sold but will update with actual pictures which will be post 4 Specs pulled from the net: Compressor Wheel: 56mm/76 Turbine: 58mm/65mm Turbine housing 9cm^2 Undivided housing Take $150 plus shipping.
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com Last edited by Madkidd007; 04-08-2019 at 09:38 PM. |
Re: He341 turbos
More detail
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
Re: He341 turbos
1st one of unknown condition sold on eBay, the one off my actual truck still available but will be going on eBay tonight
Re: He341 turbos
Housing was modified by drilling mounting holes to use on a flipped manifold, so it now uses four bolts instead of two bolts and two studs. Personally run on my truck for 3-4 months, with the wastegate hose zip tied it would boost to 32 lbs on a VE 12 valve with 5x0.12 injectors. Center section was rotated to reclock but can easily be rotated back to stock location for use on a factory truck.
Re: He341 turbos
Sold on the ebay
| Bookmarks |
