Old 03-25-2019, 03:34 PM   #1
clemsonteg
Burb Frame vs. Truck Frame
Are burb frames wider in the rear? I am trying to install a No Limit shock relocation kit on my burb and the shocks are angled in toward the center of the truck like the top mount is too far out. The only explanation I have is that the frame is wider on the burb and the mounts are designed on a truck frame.
clemsonteg is offline   Reply With Quote
Old 03-25-2019, 11:58 PM   #2
Captainfab
60-66 Nut
Re: Burb Frame vs. Truck Frame
The '63-'66 C10 Suburban/Panel frames are the same width as the '63-'66 C10,20 pickup frames. The '60-'62 C10 Suburban/Panel frames are the same width as the '60-'62 C10,20 pickup frames. The '60-'62 frames are wider in the rear than the '63-'66 frames.
Old 03-26-2019, 09:57 AM   #3
clemsonteg
Thanks, Captain. I guess there is some other reason for the shock mis-alignment.
Old 03-26-2019, 10:38 PM   #4
62bagger
62bagger's Avatar
I used then on my 62 fleetside and I had to trim them to 1" wide and they lined up fine.
62bagger is offline   Reply With Quote
Old 03-29-2019, 10:59 AM   #5
clemsonteg
Which part did you trim, the upper mount?
Old 03-29-2019, 03:41 PM   #6
62bagger
62bagger's Avatar
I trimmed the upper mount to 1" wide and it lined up with the bottom shock mount.
Old 03-29-2019, 04:55 PM   #7
clemsonteg
Thanks! Trimming may be in my future as well, although I don't understand why it is off so much when my burb is a 66 and the part is made for it.
