Old 03-25-2019, 10:43 PM   #1
allchevy58
allchevy58's Avatar
Aftermarket grill support panel
Which after market grill support panel fits the best? Metal guy and body shops I check with said buy a new one. Cost more to fix mine.
Also looking for rear upper shock mounts, the ones on my 1972 GMC K2500 will fit my 1964 C30. Holes are already in the frame.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 03-25-2019, 11:54 PM   #2
'63GENIII
'63GENIII's Avatar
Re: Aftermarket grill support panel
I shopped around for a good used one. I hadn't heard much good about the AM or re popped ones from poor fitment to thinner metal. Didn't feel like taking a chance with having to do a bunch of body work to get it to fit.
My old one was fixable but probably like yours, rotten at the mounting points. Seems that the battery acid got down there and sat.
I think the cost of fixing the original might have been the same or less money than "adjusting" a new one to fit when I was looking into it.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 03-26-2019, 12:16 AM   #3
Captainfab
60-66 Nut
I would think that it would cost about the same to fix that original that it would be to buy an aftermarket grill panel and then possibly have to rework it to fit. There is no guarantee that an aftermarket grill panel will bolt up without having to rework it.
To fix your original grill panel, I would find another to donate that section that is damaged, cut and weld.
