Old 03-26-2019, 12:30 PM   #1
chris989
ball joint lbs on pull scale
Hello all,
I am going back over my front end. I get a little "memory steer". When i rebuilt the front end I remember testing how many pounds of force require to rotate the outer c.
Everything checked out during the install, but I can not find the specification of how many pounds it should be. Something is a little tight and i want to double check.
Thanks,
Chris
chris989 is offline   Reply With Quote
Old 03-26-2019, 01:05 PM   #2
sweetk30
sweetk30's Avatar
Re: ball joint lbs on pull scale
25 lbs i think pulling with a fish scale in the tie rod hole.
also verify the u-joint on the axle is not frozen up . jack up front end and turn the wheel . then try and spin the tire . if the joint is frozen or sticking it will be hard to spin the tire.
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 03-28-2019, 06:01 PM   #3
DieselSJ
Not enough caster will cause that as well.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find
87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4
DieselSJ is offline   Reply With Quote
