64 rear axle bearing
Hello all, 2 questions. on my rear axle bearing it has a washer behind it which repair manual calls it a bearing retainer and says to replace when replacing the bearing, but can't find them anywhere, any advice. Next, one bearing i was able to pull it out with my hand the other had to use bearing puller, anyone got a clue on that. tks for any help.
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: 64 rear axle bearing
Are you working on a 12 bolt or a Dana 44?
12 bolt
Moderator
![]() ![]() Join Date: Aug 2011
The 64 12 bolt uses a somewhat special wheel bearing as I remember. The 12 bolt truck bearing that was sent with my rear end "kit" was not correct for that year. I would have to be in Texas to get that info though.
Had to drive the new bearings in, not sure what was going on.
60-66 Nut
The axle bearings are supposed to be a tight fit into the ends of the axle tubes.
yes i know they are suppose to fit tight, but can not figure out why old one was so loose. thanks for all input..BY the way captain i switched my 64 to 700r4 auto and i still run the 6 cyl with 1 barrel do you know where i could find a bracket for the kickdown cable,
![]() Join Date: Feb 2017
the 63 and 64 outer rear wheel bearing are different to the other year 12 bolt bearings-they have the press on backing plates and different size bearing
Moderator
Maybe 63 and back have press on backing plates? My 64 did not.
its 63 and early 64 12bolt axles with 17 spline-the later design with 30spline axles are all the same
#11 | |
60-66 Nut
On a 700R4 it is not a kick down cable. It is the TV cable and if it is not connected and adjusted correctly, you will burn up the trans in a short time. Have you checked with Bowtie Overdrives for the bracket? I'm not sure if anyone makes a bracket and the necessary geometry components for a I6 with a 1Bbl. If BO does not have what you need you will have to fabricate all the components yourself.
Thanks cap i will check with bowtie
