Lights go dim ,charging problem ?
My 67 is completely rebuilt frame up and I can drive it now. Everything works great , but sometimes I notice that my lights will all of a sudden get dimmer , and they stay like that. whats up ?I have a new battery and almost all new wireing.any suggestions as to what to look for would be appreciatted. Thanks
I would check all grounds and measure the voltage output at the battery with the engine running. Voltage should be between 13.5 and 14.5. If not then the alternator, (regulator?) should be checked.
Jim |
does it only happen when you are stopped at stop light (in gear) or does it happen when you are driving around (moving), and also do you have a big stereo?
Shawn |
Old member
Check your altn. belt and make sure it's tight.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
It happens when I am driving. I do not have any stereo in it yet. I will check the other things suggested. thanks
Robert Olson Transport
![]() Join Date: Oct 2002
check the ground straps at the tail lights and on the frame thats prolly where the problem is if the problem is only with the taillights
