03-28-2019, 03:26 PM | #1 |
Tie rod question
So I have a 67 long bed that I put disc brakes from a 71 on. I am waiting for my inner tie rods to show up to be able to finish and get an alignment. My question is how do I determine how to adjust them initially so I can drive to the shop a mile away. I wasn't sure that counting threads on my original tie rods would be right considering steering knuckle etc are different now
03-28-2019, 03:40 PM | #2 |
Re: Tie rod question
I would measure it off the old one. measure to the middle which is usually where the grease fitting is.
If you really want to get get close, and actually perfect on the toe. pull strings on jack stands from front to back of wheels. Space the string equally to the middle of rim front and back rims. Then measure distance to string from front and back of the front rim. adjust tie rod sleeve until measurements are the same. this is with the truck on the ground. I used pieces of laminate under tires so they would move when adjusting tie rod.
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
03-28-2019, 10:47 PM | #3 |
You can eye-ball the tires with the rear tires to get it close enough to drive a mile.
03-29-2019, 01:21 AM | #4 |
If you measure your old ones good enough, and you had a decent alignment on it before, match up your new ones and save the cost of an alignment.
Or if you are really worried about it, there are TONS of ways to do an alignment in your garage, ranging from eyeballing it, to jackstands and string etc etc etc. https://jalopnik.com/how-to-do-your-...d-t-1820555295 http://speed.academy/diy-wheel-align...ide-explained/ the list goes on, theres even tons of youtube videos on it. If you are dead set on getting and alignment when you are done with your work, eyeball it and drive it down the road, you wont hurt anything. |
03-29-2019, 09:19 AM | #5 |
Tape measure the front of the tires vs the back. Try to get it as even as possible. Move it back and forth a bit without touching the steering wheel after making adjustments
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
04-14-2019, 10:34 PM | #6 |
Re: new Tie rod question
Just when I thought I was good...so I have everything together and for the outer tie rods to torque to spec it compresses the boot quite a bit and the threads are way past the hole for the cotter pin, and still loose. I have made sure they gave me the correct ones and contacted the guy I got the spindles/rotors etc and he verified they are from a 71...idk where to go from here? Are outer tie rods for a 73+ bigger?
04-14-2019, 10:59 PM | #7 |
Yes. Outter tie rods for a 73-87 are larger.
04-14-2019, 11:05 PM | #8 |
04-14-2019, 11:12 PM | #9 |
With the tires a few inches off the garage floor hold a pencil to the center of the tread with one hand (something to brace and steady your hand helps and spin the tire with te other hand to put a line all around the center of the tread. Do this on both tires. let the truck down bounce it a few times to settle the suspension and measure from line to line on the back side and from line to line on the front side and figure the difference. You want from 1/16 to 1/8 less on the front side for toe in. That is the most accurate way without alignment equipment as it compensates for any tire/wheel runout.
When I was doing front end alignment every day I would center the steering wheel fist before doing that and then if I needed to adjust the toe I would sight down the sides of both tires and do my adjustment on the side that was off the most. That kept the wheel centered and then I would drive it and make any adjustment to center the wheel perfectly.
04-14-2019, 11:30 PM | #10 |
Everything is the same minus ball joint sizes. You probably have a 73-87 spindle and a 71 outer tie rod.
