03-28-2019, 10:10 PM | #1 |
Floor pans
How much can I expect to pay to have new floor pans welded in ?
03-28-2019, 10:21 PM | #2 |
Post Whore
Re: Floor pans
Its hard to put a price on another man's work..different shops will have hourly rates and should be able to estimate it..but having done it before I would say at least a couple hundred each at a minimum...
03-29-2019, 09:05 AM | #3 |
Re: Floor pans
If you have the pans, I'd say anywhere from 1-1.5K in labor, IF you can get someone to do it. Most body/paint places are not into low profit jobs such as this. If they supply the floor pans I would say the cost will be easily 3-4K. It sounds like an easy job, but it is very maintenance intensive to remove and reinstall correctly.
03-31-2019, 03:40 PM | #4 |
Re: Floor pans
Thanks just trying to get a general idea.
03-31-2019, 10:09 PM | #5 | |
Re: Floor pans
1984 Chevy Custom 20 $2500 work done on engine and transmission 2010/ less than 1000 miles on it since. Here's my mild build thread, http://67-72chevytrucks.com/vboard/s...d.php?t=783971 |
04-01-2019, 12:32 AM | #6 |
Re: Floor pans
Are you in Wendell ID? or another state?
My museum of good intentions: 1957 3100 BBW restomod -- 1970 442 W30 |
04-01-2019, 10:22 AM | #7 |
Re: Floor pans
A lot of the price depends on how much prep work you do before you ask someone to stick the pieces of metal together. If your plan is drop the truck off with the floor carpet still in place and the new stuff in the shipping boxes in the bed, expect to pay a lot. OTOH, if you have the floor clean, dead metal cut out, edges prepped, new pieces cut to fit and edges prepped, should be reasonable. Most welding jobs involve hours of measure, clean, cut, etc. for a few minutes of welding. If you are planning on doing most of the prep work, might ask a normal welding shop if they would consider the job. Some custom exhaust shops will do small welding jobs.
04-01-2019, 11:50 AM | #8 |
Re: Floor pans
the quick and dirty is if the job is not done right from the start the cab will never be correct . friend has one now the last so called body guy had his hands on it and the cab is so far off its basically junk . but the owner is so far in to it he cant scrap the cab and said just make it the best it will be .
with todays parts market if your cab is this bad and you need full pans and the prices are this high look at a clean rust free cab . you might be light years ahead in the end . i know this is the way i go when the firewall seam gets rust in the engine bay / floor pans are to far gone / other major rust damage . good luck and ask tons and tons of questions on someone if there going to cut out your floor pans and weld in new . or you can wind up with a non square cab .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
04-03-2019, 05:52 PM | #9 |
Re: Floor pans
Here is what the floor pans in my 84 look like. The dark stuff is the under padding, I've salvaged a decent one from the junkyard and a more decent rubber mat too. They look worse than I thought but right now I'm waiting for the weather to be warmer and to do some work on the pass side inner fender first before doing anything on the floor pans. I have decisions to make, like I've said, I want to drive it this summer, not work on it all summer!!
04-03-2019, 06:50 PM | #10 |
Moderator
Re: Floor pans
You can be assured that you will need more than floor pans....
I do floor pan replacements plus rockers and cab mounts for $1800....
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
04-03-2019, 08:02 PM | #11 |
Re: Floor pans
Just piecing in the floor pans, will patch the rockers. Drive this summer not work on the truck....
04-04-2019, 08:11 PM | #12 | |
Moderator
Re: Floor pans
Have fun....
04-05-2019, 05:36 AM | #13 |
Re: Floor pans
Thanks. I'll probably do the quick way out, pop rivet. Not really sure how long I'll keep this truck. Not the best way but better than nothing.
04-13-2019, 07:01 PM | #14 |
Re: Floor pans
Thanks for the information I will try to do the majority of the prep work myself .
04-14-2019, 11:12 AM | #15 |
Re: Floor pans
Yes, looking from the other side the other day I saw the fuel lines. Raining here now (like every other 3rd or 4th day & cold) so I'll check them in a couple of days. This rain is ruining my timeline (working outside, not in a garage).
