Old 03-29-2019, 02:26 AM   #1
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
1960-63 cheap heater knobs
I have a 61 with the "cheap" heater, the control has 2 levers,1 is definitely the fan, but the other switches between defrost and heat... I am going to buy some repro knobs since mine are missing, which would be correct for the second lever? DEF, or HEAT?
Old 03-29-2019, 01:32 PM   #2
61K10
61K10's Avatar
Re: 1960-63 cheap heater knobs
Mine is the same and you need the defrost. I bought the kit (all four) and they didn't come with the little metal inserts to grip on the arms. I ran a cable to a valve on the hot heater hose so i could shut off the heater.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
