1961 crewcab
1961 chevy dash knobs
What years came with the knobs with the letters in the middle in white? I have some standard-no chrome ring, C-choke, T-throttle, and V-vent...I found the 1 vent knob I have on a 61 60 series, I am not sure what I got my choke and throttle ones off of... Did they do a L for lights, and W for wipers?
this is the only pic I have in my files, and it has the chrome ring- throttle...
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
![]() Join Date: Mar 2014
Re: 1961 chevy dash knobs
Only 1960 and 1961 I believe. No W or L.
1961 crewcab
thank you!
![]() Join Date: Feb 2019
So what does the T do? Is that a throttle lock?
What vent does the V control? Thanks |
![]() ![]() ![]() Join Date: Jan 2018
The V controls the kick panel vents.
The throttle knob is for setting the throttle at a point higher than idle for a variety of reasons. Probably got used a lot to keep a truck moving through the field while the farmer walked alongside tossing stuff in the bed
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 350, Saginaw 4 speed "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
#6 | |
And the throttle lock is a great idea. I’ve operated a lot of equipment with similar “analog” speed controls. Posted via Mobile Device |
My cigarette lighter in my 62 has a "C" on it but I think it was stolen from the choke.
#8 | |
| Bookmarks |
