Questionable
Fuel Spider -> Anything else to change while there?
'98 Sierra 5.7L
89,500 miles I have no maintenance records before 80K miles Technically not running rough. "OK" throttle response. Oil pressure sender jumpy. No visible top-end leaks. If budget was unlimited and I'm in the top end replacing the spider, what's worth doing at the same time? So far from digging on posts over several hours, I've read:
Anything else worthwhile? Note: I don't have any coolant leaks or gurgling sounds at the heater core.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
| Bookmarks |
