47 Thriftmaster engine swap
I can get a 235 from a 53 belair. It came attached to a powerglide.
My question is can i use it with my sm420 and put an 848 head on it. Should i also use a 261 camshaft? |
Re: 47 Thriftmaster engine swap
I had a 235 from a DelRey installed in my '47 Thriftmaster. I later had a sm420 from a dumptruck put in too, so I know it can be done. I got a shortened shaft water pump, but the radiator is also mounted forward, so I think an unmodified waterpump would work if you mount the radiator forward.
'47 Panel to '88 K2500 Frame Swap Mechanical Speedometer Drive Solution 1947.2 1 ton Chevy Panel 1955.2 Chevy 6700 Bus/RV 1990 Chevy K1500 |
It already had a 235 out of a 62 pickup. Still need to modify?
May need a pilot bushing? to go from automatic to manual transmission. I have the hydraulic lifters, they work fine.
53 Bel Air powerglide 235 should be a pressure oiled engine so that is a plus.
The pilot bushing install could be an issue if the crank isn't drilled for a pilot bushing. The water pump issue isn't a big deal and surely not worth the uproar. There are several ways around that if the pump shaft is too long. I don't see any gain with a 261 Cam and it might be a loss performance wise Plus as Second series said the hydraulic lifters are pretty nice to have in a lot of respects.
How about 848 head on that?
I'm not really into the older sixes performance wise. I have rebuilt a number of them back to stock over he past 50 something years but naever changed parts around to get a performance boost. You might snoop around on https://www.stovebolt.com/ to see what the theory is. Unless there was a need to pull the head I'd probably leave it as and drive it a while.
