Old 03-29-2019, 11:02 AM   #1
GreyGhost85
2018 L83/4L80E Swap In Progress
Hey guys, just picked up a 2018 L83 and 6L80E drop out with 12000 miles. I have some general questions in regards to this set up and maybe someone could point me in the right direction. I know that I need to get the brackets to retrofit mechanical power steering pump etc... My initial question is:
1. The pedal assembly has the pedal and brake all together on the same bracket. There is not a connection on the harness that routes and connect to the pedal assembly plugs. Can I wire from pedal directly to harness if I can locate the connector? Can I ditch the brake pedal or is there a reason they are in combination?
2. Are there any DIY or HOW TOs? for L83 engine harness reworks to stand alone.
3. Are there supposed to be open or unused slots under the fuse block?
GreyGhost85 is offline   Reply With Quote
Old 03-29-2019, 11:04 AM   #2
GreyGhost85
Re: 2018 L83/4L80E Swap In Progress
Some Pics of Truck its going in:
Old 03-29-2019, 11:08 AM   #3
GreyGhost85
**made an error in post. 6l80 not 4l80
Old 03-29-2019, 01:50 PM   #4
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
PM sent
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 04-01-2019, 11:58 AM   #5
Daaaanz67
Contact swap time he’s on u-tube for the harness.
Daaaanz67 is offline   Reply With Quote
