Old 03-29-2019, 08:52 PM   #1
72longstepper
Replacing L Channel in Stepside Bed
Have bed out and fenders ready to pull off. The L Channel is rusted out a bit and is kind of ratty looking. Is this tack welded to the sides and back ? Best way to remove and replace ?
72longstepper is offline   Reply With Quote
Old 03-29-2019, 10:17 PM   #2
Boog
laying low
Boog's Avatar
Re: Replacing L Channel in Stepside Bed
Would you be referring to the angle strips spot welded to the inside, bottom of the bed sides at the floor?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 03-29-2019, 10:21 PM   #3
72longstepper
Yes
Old 03-30-2019, 09:09 AM   #4
Zeroman
Zeroman's Avatar
They are spot welded to the bedsides.
The spot welds need to be drilled out to remove the angles so you do not damage the bedsides.
New angles can either be spot welded back on, or plug welded if you do not have a spot welder.
Be sure to measure the location of the angles relative to the front/rear position from the end of the bedsides, and the vertical dimension from the top of the bedsides.
Also, there is a left and a right angle. The position of the holes will determine which is which.
Zeroman is offline   Reply With Quote
Old 05-13-2019, 11:28 AM   #5
72longstepper
So sorry about late reply. Ended up going to front end and taking that off and just started back on the bed again. At 70 my mind wanders I guess. TY for info.
Old 05-13-2019, 06:03 PM   #6
kaycee
kaycee's Avatar
I used regular steel angle on mine with bolts attached 3 per side ,I had free access to it so why not FREE99
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 05-14-2019, 07:00 AM   #7
72longstepper
Any pics?
Old 05-14-2019, 01:01 PM   #8
zicc1835
zicc1835's Avatar
Originally Posted by 72longstepper View Post
Any pics?
Subd
zicc1835 is offline   Reply With Quote
