Old 11-26-2003, 01:01 PM   #1
orange72350
orange72350's Avatar
damn quadrajet
my new engine is back in the gmc. got a carb problem.its hard 2 start, doesnt run very well on the top, and has almost no power. its starting to bug me. the timing is set at 8 degrees, and it seems as though the carb is the problem. any suggestions as to what the prolbem might be? people say its running lean, but is there anything else it might be?
thanx
dale
2003 yamaha raptor. Stock, but it still hauls!!!!
2000 skiddo mxz 700. Camoplast 1.5 inch track, jaws twin pipes, b+b can, custom built and weighted clutch, wiseco piston, high comp heads. its very fast. wow.
72 c-10 longbox. Bright Orange. Brand new 350, rv cam, performer intake, qjet, headers, 2 1/2 inch exhaust into hooker areo chamber mufflers. Body work coming soon.
"dont let yer mind wander, its to little to go places by itself."
"Forget the herse, cause i'll never die"-ACDC Back In Black
"If It's To Loud, Yer Just Too Old"
"I Love Anything Fast Enough To Do Something Stupid In"
"Instant idiot, just add beer!!""
orange72350 is offline   Reply With Quote
Old 11-26-2003, 01:01 PM   #2
dinnut
dinnut's Avatar
whens the last time it got a tuneup?
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 11-26-2003, 01:09 PM   #3
orange72350
about two days ago. new wires, plugs, cap, rotor, coil. all that good stuff
Old 11-26-2003, 01:25 PM   #4
tom hand
CCRider
tom hand's Avatar
Since your motor is not stock, play with the timing first. I would advance it a little at a time till it kicks back when you try to start it, then retard it till it just stops kicking back. Take it for a test drive, and do some full thottle pulls...up hills if possible. If it pings retard it till the pinging stops. Depending on the gas you are running I would not be surprised if you could run 12 degrees with no problem. As far as the quadrajet, they are VERY senitive to float settings, so raising the float a small amount may cure lean problems if that is what you have.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 11-26-2003, 01:32 PM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Plugged fuel filter? Or gummed up carb?
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 11-26-2003, 02:37 PM   #6
72 CustomCamper
huh ???
72 CustomCamper's Avatar
How long was the carb off the motor? And was the carb rebuilt while it was off the motor? If you take a used carb off a running motor and let it set any amount of time the seals and gaskets will dry up. When you put it back on you will have air leaks and has\ve a lean run condition...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 11-26-2003, 02:47 PM   #7
orange72350
huh. the carb was off the truck fer like 2 months. how hard is a rebuild? is it something that i can do myself? how hard is it to track down a rebuild kit for a q-jet?
thanx again boys
dale
Old 11-26-2003, 03:19 PM   #8
StingRay
StingRay's Avatar
Make sure the fuel pump is OK. I had to replace one this summer as the truck was bogging big time on the top end. It was a freshly rebuilt carb a few months earlier. I asked around and it was suggested that I check fuel pressure. It was fine at idle and through midrange but dropped severly above 2500 rpm. A new pump solved the problem.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
