03-30-2019, 08:58 PM | #1 |
Hydroboost swap help!
Hello,
I'm in the midst of an LS swap on my 71 C10. I had a 2002 2500hd parts vehicle. Along with the drivetrain swap, I'm using the hydroboost. However, the master with the hydroboost came with front and rear discs and my original master doesn't work with the hydroboost push rod. What it the easiest way to get this going? Is there a bolt on master I can use that will work with the hydroboost and the rear drums? All help is appreciated! |
03-30-2019, 09:44 PM | #2 |
Re: Hydroboost swap help!
I used my original master cylinder on my hydroboost. The hydroboost pushrod I cut and threaded for a heim joint
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
03-30-2019, 10:26 PM | #3 |
Hey, What did your hydroboost come out of? Can you give me more details on your modifications to mount the original master to the new hydroboost?
03-30-2019, 10:30 PM | #4 |
I have a radical idea!
If you look at my build thread below, I have pics of my hydroboost swap on my dually. My unit was from an 80's truck, so I'm not sure if its the same as yours. I'm using the master cylinder made for disc/drum, and for now mine is drum/drum and it works fine. But to answer your question, i know all '82 - '87 master cylinders were made for a disc/drums setup.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
03-31-2019, 06:56 AM | #5 |
Late Astro van. No modifications, it bolted right on with the correct push rod length. If you do a search on this site there might be a thread suggesting there are only two lengths of push rod pins with all the hydroboost units.
03-31-2019, 10:19 AM | #6 |
All about them Ks
I used an off the shelf new NAPA master for a 72 K20 for my setup. I’m using a hydraboost unit from an 08 Silverado 2500hd. I’ve got another unit from an 06 2500hd that is identical to the 08. I suppose they must have changed the pushrod lengths from 02 to 06.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5 lift, 35s, front dana 60 blah blah blah http://67-72chevytrucks.com/vboard/s...d.php?t=662879 69 K10 SWB: 4 lift 33s in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20s |
03-31-2019, 11:02 AM | #7 |
Here is one of the threads I have subbed to for
my future reference. Link: http://67-72chevytrucks.com/vboard/s...rod+hydroboost Hope this helps. .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
