03-31-2019, 08:04 AM | #1 |
78 high cold idle rpm
I brought an all original low mile 78 Big 10 home a week ago, still learning it's quirks.
250 straight six, factory carb. My concern today is what I think is high cold idle rpm. I get in, give the accelerator a slight tap hit the key and it fires right off but the idle is high enough it worries me. I would never choose to rev a cold motor like that. Warm it up, tap the pedal and it just purrs. It's about 25 degrees out there this morning and I'm almost worried about starting it. I assume this is a simple adjustment. |
03-31-2019, 09:30 PM | #2 |
Re: 78 high cold idle rpm
Should be a fast idle adjust screw somewhere in or near the choke linkage. It most likely will look similar to the normal idle speed adjust screw. Location depends on the carb.
04-01-2019, 06:19 AM | #3 | |
Thanks |
04-01-2019, 06:40 AM | #4 |
Note sure that is the same as your carb. You can see the fast idle screw in this image. it should be in a similar location on most carbs. On the throttle shaft, connected to the choke.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
