C25 Steering boxes
So I've got the super sloppy original steering box in my C25, and was wondering what options I have as far as upgrades go. I've been looking at these CP500 boxes, but they just say C10 and I'm not sure if I have the same box as those. Any recommendations?
https://www.summitracing.com/parts/c...ions/year/1972
1972 GMC C25 350 Muncie 465 - Daily Driver 1979 AMC AMX 304 4 Speed -Mechanic Special 1983 AMC Eagle - The Eternal Project |
Re: C25 Steering boxes
Depends on what you want, Summit also has this. https://www.summitracing.com/parts/a...olet/model/c20
Search through the applications tab there and it shows your C25. That is a remanufactured Cardone 27-7501 A search of that Cardone part # on google shows it is available at some FLAPS
'67 GMC 2500, 292, 4spd, AC |
you might have already done so, but you could try adjusting the box. make sure the rag joint and pitman arm are tight. good quality boxes are expensive.
Yup, the entire front end was rebuilt and I the rag joint has, surprisingly, zero slop. Just a super loose feeling box, which is normal for old vehicles I know
If you still have a 4 turn box, a 3 turn box would be a nice upgrade.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
![]() Join Date: Nov 2007
Red Head steering gear is a great upgrade, and you can also have them install variable steering so its a little firmer going in a straight line, and loosens up while you crank it. Goes to about 3 turns lock to lock.
Great customer service and questions answered promptly. The need a good core return but can also provide you with a label.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
If you want a manual box I have one that i removed from a 72 C20 when I switched to power steering years ago. The truck had about 27,xxx miles when I made the switch.
$50 + shipping and PP fees GMC 72 4x4 |
