Old 04-01-2019, 08:45 AM   #1
4u2nv
column shifter lever
The column shifter lever is all floppy on my 82 making it were it's getting unsafe to be sure it's in park
Is it spring loaded or ???
Anyone done a fix for this ????
4u2nv is offline   Reply With Quote
Old 04-01-2019, 05:08 PM   #2
Re: column shifter lever
Here is all the parts.
Some of the small parts are hard to find now days
Old 04-01-2019, 07:01 PM   #3
4u2nv
There's a bunch of numbers there but it doesn't tell me what they are !!!!
Old 04-01-2019, 08:03 PM   #4
Sorry forgot this. It does not list the actual parts numbers and I don't have that catalog to cross reference.
Normally from what you are describing, the spring or bushing (#6, 7, & 8) in view B are what is messed up or missing. You might find the bushings ( Genuine GM 1377083 Control Linkage Insulator/Bushing) on e-bay, but a lot of folks ask way too much for them since they are no longer produced.
This is where I got mine.
https://www.ebay.com/itm/New-Genuine...item2a3940c649
I just found a spring in the hardware store and used it to replace mine.
Old 04-02-2019, 05:32 AM   #5
Wgesnerjr
Wgesnerjr's Avatar
It is not listed in the break down above but there is a small spring under the (20) shifter lever end in the steering column bowl. that will often break causing the shifter to not spring back towards the dash.
once you drive the pin (18) out and remove the lever, you should be able to dig it out with a small pick. make sure you get all the pieces out or the new spring will not fit.
Jay Gesner
Atlanta, GA
1985 C10 Long Bed 4X2
LS 5.3, 4L60E
Father/Daughter Project
Wgesnerjr is offline   Reply With Quote
Old 04-02-2019, 05:35 AM   #6
S10Fan
Old Heap Driver
I would begin by checking numbers 3, 4, 13, 14, 15, and 17 from the illustration to see if those areas are tight. Bushings in those areas could be worn out or missing causing the feeling you're describing.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 04-02-2019, 07:41 AM   #7
4u2nv
That's were the problem is !!
Now to find a spring
