04-01-2019, 12:40 PM | #1 |
Newer clsss 5 truck hitch on a squarebody
Anyone had any success putting a hitch from a newer truck on your squarebody frame?
I want to rent trailers(500lb max tongue) and my cheap butt knows I can snag one off a newer truck in a yard or partout easily for a fraction of what a newer one will cost.
1991 Metro commuter 1991 s10 future project truck 1987 V10 backup daily/junk truck 1985 K20 Winter beater 1991 R30(squarebody) c/c flatbed towrig 1994 s10 80"wb custom build |
04-02-2019, 07:04 AM | #2 |
Re: Newer clsss 5 truck hitch on a squarebody
If you have a spare tire carrier that mounts under the bed you may have to remove it.
77 Chevy K20 Longbed 86 GMC C3500 Dually 07 Silverado 2500HD All standard cabs |
04-02-2019, 11:04 AM | #3 |
you may check my build thread.
I used a late model class 3 hitch. there is really no need for more than class 3 on a square.
1949 Chevy 3100 P/U http://67-72chevytrucks.com/vboard/s...d.php?t=302780 1976 GMC Sierra Classic C35 CCSB http://67-72chevytrucks.com/vboard/s...25#post8188825 |
04-02-2019, 12:36 PM | #4 |
That's long gone also no blazer tank.
04-02-2019, 01:50 PM | #5 |
check ebay and others . the price for a new painted / non rusted out / all new hardware hitch dropped at your door in a box is cheep .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
04-02-2019, 02:43 PM | #6 |
Checked it and cool. I know where one of those hitches is locally for $50.
04-03-2019, 01:56 PM | #7 |
I have a class III hitch on my C20. I had to move the pivot bolt on the spare tire carrier forward about 1 inch. My stock spare tire fits (23585R16), but it is very close to the exhaust. My exhaust exits out the side of the vehicle behind the rear tires.
04-03-2019, 02:37 PM | #8 |
I just put one of these on my 75 1 ton. It fit great.
https://www.etrailer.com/Trailer-Hit...leID=197522505 |
04-05-2019, 11:52 PM | #9 | |
1984 Chevy Custom 20 $2500 work done on engine and transmission 2010/ less than 1000 miles on it since. Here's my mild build thread, http://67-72chevytrucks.com/vboard/s...d.php?t=783971 |
04-06-2019, 08:11 AM | #10 |
Yeah I put it on fits great, just had to drill two holes. Watch that you dont pinch the brake light wiring while your tightening it down like I did.
04-07-2019, 10:17 AM | #11 |
I used this one - Draw Tite 75034. It fits great. I’m not sure what class it is.
04-07-2019, 09:20 PM | #12 |
Just as an FYI, but any hitch made for a 34" wide frame will work, that means a lot of Ferd frames, any GM cab chassis frame (dump trucks/service bodies with dual rear wheels)
Class 3 is normally plenty, rated at 10,000lbs but only 500 tongue weight, class IV is better at 1,000 lb tongue weight, 12,000lb max. Class V is a little overkill, but gives the best tongue weight at 1,600lb 16,000lbs max trailer. I know several camper trailers that are less then 8,000lbs, but tongue weight stays around 750, just based on design. If you can, always opt for the higher rated hitch. |
