CPP Crossmember Install
I Noticed Some Are Mounted On Top Of The Lower Framerail And In Some Pics Their Mounted On Top Of The Lower Frame Rail.
If I Go On The Bottom Will This Make A Huge Differerence With The Angle Of The Transmission?? Also Which Holes Are Correct To Use With a SBC And a Turbo 350? Thanks Guys Posted via Mobile Device |
![]() Join Date: Sep 2007
Re: CPP Crossmember Install
it sits inside the frame. unless youre bagged, then you might want to check your angle and see if mounting the crossmember under the frame will give you a better straight shot when slammed
1967custom |
