np205 reseal, on vehicle!
I need to reseal the retainers for the front output and the rear output. Is it possible to do this with it on the truck if I was to move the cross member out of the way? also the rear retainer is the 8 bolt retainer not the small 5 bolt retainer. Is that doable on the truck or does it need to come out?
![]() Join Date: Mar 2003
Re: np205 reseal, on vehicle!
Rear output 8 bolt retainer you'll have to be careful with removing the assembly as not to drop the needle bearings into the case. It can be done. I would question the input seal at this point if everything else is bad
The sm465 is my transmission. Its full of oil everytime I check it so I'm sure the seal is prolly fine.
![]() Join Date: Oct 2009
You've probably already seen this - and I realize your goal is to do this on the truck - but there are some great ref pics in this thread that may be helpful regardless of which route you take. http://67-72chevytrucks.com/vboard/s...d.php?t=469726
Mine needs it, too. I'll be dropping mine. I figure it's time to do the adapter and transmission, too. Mine's a TH350.
#6 | |
All about them K’s
![]() Join Date: Jun 2014
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
#7 | |
![]() Join Date: May 2012
![]() j
White K20 |
I bit the bullet and removed my T case from the truck and have been resealing it. My question is will 90w gl4 oil be fine for this?
Sorry! for the refill of the tranny.
#10 | |
J
White K20 |
Also make sure you use the gaskets no sealant when mounting the adapter to the T case and transmission. Those tolerances are very important
J
White K20 |
Another also. Some of the bolt holes on the PTO covers are through bolts. You might want to dab a little sealant on the threads. I think a couple bolts on the transmission side of the adapter are through bolts too. Just look at them all. I added a dab of thread sealant to a few of my bolts. I have no leaks, and I am happy.
J
White K20 |
