Old 04-03-2019, 08:37 PM   #1
focusedontheprize
focusedontheprize's Avatar
Fuel Tank Sending Unit Connector/Harness
Almost done with tidying up the harness in the truck. The truck was originally a TBI truck, but someone removed the motor and "modified" the harness to get it to work.
The last puzzle piece (at the moment) is the fuel tank sending unit connector. I need to replace the wire and realized the fuel tank sending unit connector is falling apart and is not salvageable.
This is what it looks like (below). I took some quick measurements and mine measures 0.420" ID and 0.560" OD. Has anyone swapped this prior and do they vary in size? I thought the one on my 1986 was larger.
Either way I did order it from RockAuto to see.
focusedontheprize is offline   Reply With Quote
