04-03-2019, 09:25 PM | #1 |
Diesel to gas?
Throwing around the idea of taking the 6.2 out of the 84 shortbed and going back with a 350. The 6.2 runs pretty good but smokes like a freight train. While I like the 20 mpg when I drive it I think I would like driving a gas short bed again better. Other than flushing the fuel tanks and lines out I don't think I would have to change much with the fuel system. I believe the engine frame mounts are the same but not sure what I would run into on the wiring harness. If I were to make the switch I would make sure it had the AC put back on. Can I use the Diesel harness or do I need to do something different? The truck has a 700r4 so I think I could change the converter and the governor and be good. Anything else I need to think about?
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
04-03-2019, 09:41 PM | #2 |
Post Whore
Re: Diesel to gas?
May need front springs with the weight loss...
04-03-2019, 10:10 PM | #3 |
Re: Diesel to gas?
I don't know what your emission requirements are in your state, but it might lock the vehicle in the state with emissions that are non-compliant. How many miles are on the motor now?
Are you planning to go fuel injection, which might not give you the mileage you are getting now, or a regular carb, which will definitely not give you better that what you now have.
1981 C-10 Longbed, 250 (4.1) 2bbl Varajet, THM-350C. Some of the Build progress: https://www.youtube.com/channel/UC_W...foLyeDq_WQPNmA 1981 Harley Davidson. Credentialed, semi-retired A.S.E. technician. If you don't like free advice, Ask Someone Else and pay for it. |
04-03-2019, 10:14 PM | #4 |
I have a radical idea!
Re: Diesel to gas?
You pretty much have it covered. If you are going run a standard non-computer HEI distributor, you can run the power wire going to the injection pump to the distributor and all of the other sensors would work. In addition to the converter, you'll need the correct bracket and TV cable to control shifting of the 700R4.
All that said - If you haven't totally made up your mind - smoking is a 6.2L usually either injectors or the IP going south. I have 2 truck that are running turbo'd 6.2's and they both have at least as much power as a normal stockish 4 barrel 350, a lot more torque, and of course way better fuel mileage. They are a whole 'nother thing with a little tuning and turbo. Plus, they sound so cool! https://www.youtube.com/watch?v=Vsvn9zB3f9M&t=12s https://www.youtube.com/watch?v=A1iHKarTFK0
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
04-04-2019, 04:19 PM | #5 | |
Re: Diesel to gas?
04-04-2019, 08:33 PM | #6 |
resident oilfield trash
Re: Diesel to gas?
If I was going to go through all the trouble of switching it why not go with a 5.3
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada |
04-05-2019, 12:43 PM | #7 |
Re: Diesel to gas?
If it's freight training that bad, likely just injectors.
Big Nate Carp. Local 224. Buy made in the USA! 03 F350 6.0 Daily Race Truck. 79 C70 366 Project Dump. |
04-05-2019, 03:55 PM | #8 |
Re: Diesel to gas?
I do have a LM7 sitting in a parts truck that needs the transmission rebuilt. I don't think I am looking to get into that much with the truck at this time.
04-05-2019, 03:56 PM | #9 |
Re: Diesel to gas?
I don't know a whole lot about the diesels. I know it runs pretty good other than it smoking. I will have to look into what injectors will cost for it.
04-06-2019, 09:42 PM | #10 |
Re: Diesel to gas?
You'll regret it... sbc's get the worst mpg ive ever seen
1979 Pontiac LeMans 231/Th350 1982 Chevrolet Silverado K10 6.2 Diesel/700r4 1984 Buick Regal Limited Sedan 4.3 V6 Diesel/200r4 (Hens teeth rare) 1991 Chevrolet Silverado K2500 5.7/700r4 1999 Chevrolet Base LS K2500 6.5TD/4L80e |
04-09-2019, 06:15 AM | #11 |
Re: Diesel to gas?
Roy, shouldn't be more than 600 dollars for a set of good reman or even new Bosch's. New glow plugs wouldn't hurt as well. Glow plugs please use only acdelco. Parts store house brands are not gonna last, as i sit here pulling a head in a 7.3 because an autolite broke off. Both of those are easy to change out. Also if you're getting 20 mpg now, you'll get better since you won't be putting out unburnt fuel.
