04-03-2019, 10:06 PM | #1 |
Active Member
I'm at my wits end with my truck.
Good evening gearheads,
I have a problem, perhaps several problems. My '72 C20 with a 350 and a Holley 600 carb will not cooperate at all. Here's the gist of it all. I got customer mufflers put on last November, NASCAR style. I should back up a few months and mention I had the brakes bled by a shop and the guy mentioned the motor was running rich. I hadn't addressed that issue when I got the new mufflers put on. So, the mufflers get installed and once they're in, I can't get the truck started. It would fire, but wouldn't run at all. This was in November. after several attempts at starting it, it kicks over and runs long enough to make the 11 mile drive back to my garage. After sitting for a week, I attempt to start it again and take it for a spin. She runs for 10-15 minutes and then stalls. Every time I gave it gas, it would peter out. It took me another several attempts to get it started long enough to get it into the garage. Fast forward to last week, on first startup in idles for 5-7 minutes and dies. I adjusted the thermostat back to the factory setting, (matching the hash marks on the thermo cover and the carb body) and checked the vacuum on the PCV Brake booster port and got a steady 17Hg. I moved the idle mixture screws in and out to the same settings on each side and still nothing. I tried it tonight and it barely wants to stayed started and if it does succeed and stay idling roughly, it dies when I hit the throttle. I'm not a carb guy or an electrical guy, so I'm learning as I go here. I do still have the points system in it and that's about it. So, any of you who read all that, if you have any suggestions or advice, I'd greatly appreciate it because I can't take it anymore. It's driving me to drink. I guess that ain't so bad. Thanks for reading.
The Dude abides. |
04-03-2019, 10:17 PM | #2 |
Re: I'm at my wits end with my truck.
[QUOTE=thedudeabides86;8500403]
I adjusted the thermostat back to the factory setting, (matching the hash marks on the thermo cover and the carb body) I'll give it a go, but I think you may be confusing the choke with the thermostat... Care to elaborate on that?
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. Last edited by cornerstone; 04-03-2019 at 10:19 PM. Reason: I answered my own question |
04-03-2019, 10:22 PM | #3 | |
Active Member
[quote=cornerstone;8500415]
The Dude abides. |
04-03-2019, 10:27 PM | #4 |
Ok you need to start by troubleshooting what you are missing to make it run right.
Ignition, fuel and air/compression. Is it getting fuel to the carb??too much fuel to the carb?(fuel soaked plugs) Is it getting a good spark.Test the spark.Also check the timing. Good air flow and compression. Check to make sure the carb choke is opening.Do a compression check. |
04-03-2019, 10:38 PM | #5 | |
Active Member
What's the best way to test spark? Can you check timing correctly when you can't get the engine to run? The choke plate is opening accordingly, I think. Checking compression is checking each cylinder once you remove the spark plug and turn the engine over one revolution?
The Dude abides. |
04-03-2019, 10:43 PM | #6 |
From your description of how its acting, I'd venture a guess and say that it may be a combination of a closed choke and a rich carb... Take a spark plug out and see what direction that points you in.
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
04-04-2019, 12:30 AM | #7 | ||
"I ain't nobody, dork."
Wire the choke open and just pump the gas a few times and get it cranked up. You'll have to feather the throttle to get it to stay running until it warms up a bit. If it will run and drive with the choke wired open, then you had the choke adjusted improperly.
Run the idle mixture screws in all the way and gently bottom them. Turn them 1 1/2 turn out on both sides. There's your baseline. The screws do nothing but control idle mixture. After that it's the accelerator pump (which you see squirting as you move the throttle), and then it's on the primary fuel metering circuit. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
04-04-2019, 07:03 AM | #8 | |
Anything else that is doing that, not good, your float level is too high. Easy fix tho. If that’s ok, then proceed on with the post from GASoline71
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
04-04-2019, 07:13 AM | #9 |
floats too high or power valve is faulty
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
04-04-2019, 09:31 PM | #10 |
Post Whore
Does the truck have electronic ignition? If so it is possible when the mufflers were welded something may have gotten fried by stray current. Years ago I lost an alternator after getting new mufflers, which really sucked at the time, since I had spent all my cash on the mufflers.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
04-05-2019, 10:56 PM | #11 |
Guest
Posts: n/a
Fuel starvation could be an issue; on my 69' FJ40 I had the same symptoms; dirty carb was my culprit. On the other hand, as posted above, there could be many issues that cause that problem. m
04-06-2019, 12:44 AM | #12 |
Dirty gas tank clogging carb
04-08-2019, 02:00 PM | #13 |
It could be heat soak possibly try putting a plastic carb spacer. my truck did something similar and the plastic spacer fixed the problem
04-08-2019, 08:29 PM | #14 |
You were fine until you installed "customer mufflers", I would remove mufflers and see what happens. Maybe they are clogged with grease rags or rat nest or they just have too much resistance.
Watched a mechanic chase a miss for several days before he found a grease rag stuck in one of the intake runners. |
04-08-2019, 09:25 PM | #15 |
A vacuum leak is also possible. Might spray brake cleaner around the base of the carb to see if the idle changes and look for open ports or broken lines.
If you changed the choke, that's a possibility too. |
04-08-2019, 10:22 PM | #16 |
I had a friend with a el Camino who went through a similar problem, changed the carb, checked fuel pump, went through everything, finally found out the exhaust pipe inner wall collapsed like in this pic..
https://rennlist.com/forums/attachme...ed-exhaust.jpg
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
04-09-2019, 11:21 AM | #17 |
If there is a clog in the exhaust, you can use a vacuum gauge to see it. It should start out with normal manifold vacuum then slowly drop to 0.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
04-13-2019, 09:19 AM | #18 |
Still plays with trucks
I had a similar problem on a car I bought years ago that sat quite a bit before I got it. Adjustment of the air/fuel mixture screws did little to nothing on the vacuum gauge due to accumulated evaporated fuel residue in the metering blocks. Tore it apart and found a ton of gunk and residue in every possible location fuel could have been. Nothing could have worked right in that carb the way it was. I'm surprised it ran at all before I rebuilt the carb. You could have a similar problem causing you grief.
Did you see much of a change in the vacuum readings when you adjusted the mixture screws? These small passages are the easiest to get clogged with fuel residue or even dirt particles if the truck was driven without an air filter. You should be able to make severe changes to the vacuum readings from these adjustment screws so if you don't have that ability then the carb is most likely dirty internally and could benefit from a good clean out and freshen up kit with all new gaskets and accelerator pump diaphragm plus a set of fresh needle & seat assemblies. The kits are cheap and the 600 Holley carb is really simple to take apart and reassemble properly unlike a Q-Jet so it is something a first time carb rebuilder could handle if they have just basic mechanical skills. I'm sure there are some videos out there to guide you through the process that could be helpful to you.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
04-13-2019, 10:11 AM | #19 | |
1981 C-10 Longbed, 250 (4.1) 2bbl Varajet, THM-350C. Some of the Build progress: https://www.youtube.com/channel/UC_W...foLyeDq_WQPNmA 1981 Harley Davidson. Credentialed, semi-retired A.S.E. technician. If you don't like free advice, Ask Someone Else and pay for it. |
04-13-2019, 11:26 AM | #20 |
First, take a spare spark plug and pull off a wire to hook to it. Crank it and look at the spark. Make sure it's bright blue and will jump to ground from 1/4” away. If that test shows no good then start looking for a bad condenser, weak coil, or bad pickup coil if hei.
If you have good spark then check the fuel. While trying to get it to idle you should see some fuel dripping into the primaries on the carb. You should not see fuel pouring in, and you should not see fuel dripping into the secondaries. If you see excess fuel then either a float has hung, a needle valve went bad, or the fuel vent is plugged. Last, if nothing else looks unusual pull the fuel line off going to the carb. Add a piece of rubber line to it and grab a container. Crank it over and see how much fuel is pumping out. Just cause somebody says it's running rich doesn't mean they know what they're talking about. If you're barely getting any fuel it will stall out when you open the throttle. Could have a failing mechanical pump or even a pump lobe worn off the cam. |
04-30-2019, 12:40 AM | #21 |
Did this problem ever get fixed?
04-30-2019, 01:14 AM | #22 |
Guest
Posts: n/a
05-16-2019, 05:58 PM | #23 |
Active Member
Hi Everybody,
Sorry for the lack of updates on this issues. A fellow coworker mentioned that I should add some HEAT to the gas thinking perhaps I had water in the gas. I added a couple bottles of HEAT and changed the distributor from points over to and HEI and it's been starting up and driving like a hotrod. I'm not sure where the problem was, but as long as it's driving forward and starting, I guess I'm happy. Next project on it is an alignment and hopefully some new tires. Anyone know what the widest tire is you can put on the rear without any complications? I've always liked the look of the wide tire in the back.
The Dude abides. |
05-17-2019, 12:40 AM | #24 | |
05-17-2019, 06:25 AM | #25 |
265/75R16 are the same diameter as the 235/85/16, but an inch wider. I had these on my truck for a bit. Not sure what rims they were mounted on (width, backspacing). Factory rims are 6" and shouldn't have wider than a 235, but you CAN fit wider.
