Old 04-04-2019, 09:39 AM   #1
weider1717
what backspacing would create less rub when running 10" rallys?
Not sure what my original 8" rally back spacking / offset is?
But if I lift my k10 2.5" and run 33x12.50's on a 10" rallys (they don't make 9")
what off set would HELP with rubbing issues due to the wheels being wider than the 8" rallys?
I like the beefier look so I thought if you counter some of the extra width with more / less offset maybe that would help some?
thanks guys
weider1717 is offline   Reply With Quote
Old 04-04-2019, 10:46 AM   #2
Re: what backspacing would create less rub when running 10" rallys?
Factory 8" ralleys are 4" back spacing
Old 04-04-2019, 03:22 PM   #3
Loco83
Loco83's Avatar
5" BS for 10" rallys.
Loco83 is offline   Reply With Quote
Old 04-04-2019, 03:26 PM   #4
OARNGESI
OARNGESI's Avatar
If possible get more bs upfront so the front wheels don’t stick out farther
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 04-04-2019, 11:15 PM   #5
weider1717
Thanks for the replys guys this helps a lot.
So, if I do a 4" and 35's on an 87 k10 and go with 10" rally wheels with 5" back spacing will they still rub worth than 35's on the 8" wheels? if so how bad worse? OK to order up if I like the 10" look.
thanks fellas
Old 04-05-2019, 10:07 AM   #6
SCOTI
SCOTI's Avatar
Look @ your current set-up. Where does it rub?
If it's rubbing somewhere on the inside (tie-rod @ rim; fender lip; etc.) & you add more backspacing, it will only get worse.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
