Old 04-04-2019, 03:21 PM   #1
54blackhornet
54blackhornet's Avatar
Replacing Factory Single Exhaust ?
Does anyone offer a single exhaust system kit ? I really don’t want to go to dual exhaust...thanks
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 04-04-2019, 03:33 PM   #2
jbarron
Re: Replacing Factory Single Exhaust ?
Try rockauto
'72 3/4 Cheyenne Super 402/TH400 Gear Vendors
'72 3/4 Cheyenne Super 350/200R4
'50 1/2 Chevy 3 Window
jbarron is offline   Reply With Quote
Old 04-04-2019, 11:56 PM   #3
Coalkracker
Ive looked everywhere without any luck. I even called a few manufacturers and couldnt find anyone who makes one for a v8.
Coalkracker is offline   Reply With Quote
Old 04-05-2019, 07:53 AM   #4
Ozark Tim
Ozark Tim's Avatar
Walker makes the Y pipe and some of the exhaust pieces. Go to their website and it allows you to put your vehicle make, model, year, leafs or coils etc.
Ozark Tim is offline   Reply With Quote
Old 04-05-2019, 11:20 AM   #5
54blackhornet
Thanks guys
71 C-20
07 Magnum RT AWD
Old 04-05-2019, 08:27 PM   #6
BCOWANWHEELS
why single.......... duals is better all around 2 1/4 with caddy mufflers you wont regret it.
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 04-06-2019, 06:19 AM   #7
Boog
laying low
Boog's Avatar
Any corner muffler shop can make you a single system.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 04-06-2019, 09:55 AM   #8
Joesjunk
Joesjunk's Avatar
The walker Y pipe number is 40346 for a small block. You might also check out this place, I bought a 4x4 y pipe from them http://waldronexhaust.com/
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 04-06-2019, 12:22 PM   #9
BCOWANWHEELS
Just plain duals is perfect, you dont need the racey stuff
Old 04-06-2019, 12:25 PM   #10
BCOWANWHEELS
Plus the sigle y pipe under the engine oil pan is great for raiseing oil temp and making it hard to change oil filt
Old 01-30-2020, 11:35 AM   #11
Bearhawg
Bearhawg's Avatar
I know this is resurrecting an old thread but I have a follow up question. I have a bone stock small block with the original Quadrajet set up and ram's horn manifolds. I drive and use the truck as originally build, hauling and pulling. I've always heard that reducing back pressure (adding a free flowing dual exhaust) can reduce available torque. Or is the answer "oh know, here we go again with this debate" Thanks
Bearhawg is offline   Reply With Quote
Old 01-30-2020, 12:07 PM   #12
54blackhornet
I asked my only local exhaust guy about both. His reply was “ About $500.00 for either one. About the same amount of labor to fab up, with single going up in diameter.
71 C-20
07 Magnum RT AWD
Old 01-30-2020, 02:08 PM   #13
maverickmk
maverickmk's Avatar
If your motor is stock I think any loss or gains would be negligible.
Die with memories, not dreams.
Not to brag, but I don't need alcohol to make really bad decisions.
1969 GMC Short Step Side
maverickmk is offline   Reply With Quote
Old 01-30-2020, 07:09 PM   #14
truckster
truckster's Avatar
That would be true if you ran straight pipes from each cylinder, because you would be losing the scavenging effect of having multiple cylinders empty into one manifold or header. However, beyond that there is almost no appreciable positive effect of back pressure unless you're running a turbo.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 01-25-2023, 06:30 AM   #15
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
When I got my truck a previous owner had put duals on the stock rams horn manifolds and use the original 2 inch exhaust pipe and added a 2 1/4 to the other side. I had it all removed and went to 2 1/4 inch pipes with an H Pipe front to back and Dynomax Turbo Mufflers that are 25 inches long. 1972 C10 longbox has the stock untouched 350 V8 with a 4 bbl carb engine. After the work was done and I pulled away form the muffler shop I could feel the difference in power from just doing that. I think was mentioned that a good running engine with stock rams horn manifolds and front to back 2 1/4 pipes and what ever mufflers work for you will be all you need. Its too bad I can't post a video of my truck idling on here as think you'd like the sound.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 01-25-2023, 10:20 AM   #16
mr.mud1
mr.mud1's Avatar
i searched all over for stock dual exhaust parts for my big block 72 Cheyenne Super,it came with duals.i spent a bunch of years a long time ago running a muffler shop with a bender so i know my way around that stuff.i couldn't find anything and emailed Walker in Tennessee,they reported back that they no longer made parts for our trucks??so i made my front pipes,bought 2 1/2 in and 2 1/4 out Walker mufflers from Rock Auto and as Joe said,went to Waldron's in Michigan for tail pipes.i think they offer a single system.they do make nice stuff and i've used their stuff on several cars.here again,as Boog said,any good corner muffler shop can make what you need,adapt another crossover if need be and make the rest.
mr.mud1 is offline   Reply With Quote
