Old 04-04-2019, 10:00 PM   #1
Rick Bollinger
Shortening driveshaft
On my 68 lwb 2 piece drive shaft is there any reason I cannot shorten it at the splined end of the front driveshaft? The reason I am thinking about that end is because the balance weights are on the other end and would need to be moved. I assume there is a shoulder on the splined end that slips into the driveshaft similar to the yolk end. And also when the front driveshaft is together the yokes do not line up. But I believe they are suppose to. Can someone please confirm so when I weld it back together it will be right.
Rick
Rick Bollinger is offline   Reply With Quote
