04-05-2019, 02:33 PM | #1 |
Passager side window won't roll down
I can only get it to roll down about an inch. Using some serious force. I oiled it up one time and it was buttery smoth now it just locks up I can push past It at first then it hit that spot and won't buge. Even With me pushing top of the window down It rolls up really easy thoue.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original ) 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
04-05-2019, 02:44 PM | #2 |
Re: Passager side window won't roll down
Could be the roller has popped out of the track. Pushing will only make it worse. You need to remove door panel to find out.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
04-05-2019, 02:48 PM | #3 |
I've already removed the door panel and every thing seem so be in place. I'm don't know how to tell tho. Never realy messed with the regulater before
04-05-2019, 02:53 PM | #4 |
roller wheel could be broken and jammed or the spring could have popped out of the housing
1967custom |
04-05-2019, 03:13 PM | #5 |
Well I looked up what the regulater looked like in the door and the rollers are in place I beleve. I can reach in thare and feel around and nothing seems out of place. If the rollers where poped out wouldn't it be hard to roll up to. Ps now it won't role down at all
04-05-2019, 03:24 PM | #6 |
the roller could break and the piece still attatched to the arm could get lodged in the track
1967custom |
04-05-2019, 04:05 PM | #7 |
I think the rollers are not broke. I flet around and they seem fine. Kida hard to tell. If it is a broken rolder then how could I get my window down. I think the spring is also broken with the window up all the way I can still get a 1\4 turn on the handle
04-05-2019, 04:44 PM | #8 |
yup its probably sprung most likely. time for a new regulator
1967custom |
04-05-2019, 04:46 PM | #9 |
Or... I've seen this happen when the felt in the channel gets torn. It bunches up under the glass and won't let it go down. Check your felt and see how it looks and feels.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
04-05-2019, 05:03 PM | #10 |
Good call on the felt. It was all tore up so I tore most of it out. It sadly did not help
04-05-2019, 09:54 PM | #11 | |
The Older Generation
LockDoc
04-06-2019, 09:05 PM | #12 |
When the felt lining is torn, deteriorated, or otherwise gone, the metal guide bar attached to the glass and runs in the channel will dig in and cause the window to "lock up".. If a chunk of the rubber that the felt is attached to is missing, the guide bar will grab and cause the "lock up"..
Forcing the issue will (if it hasn't already happened) damage the regulator mechanism.. Sounds to me like it's time for you to overhaul the entire window raising/lowering mechanism.. |
04-06-2019, 11:41 PM | #13 | |
If you have to overhaul the door, once done you'll see how easy. Maybe you'll find the problem and all else is good, though you'll at least need new sweeps. If by some luck your regulator is good, then remove the oil and be generous with white lithium grease. Randy500 has a nice straight-forward write up on how to do it.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 04-08-2019 at 12:03 PM. |
04-07-2019, 01:45 PM | #14 |
Thanks for all the help I removed the 3 screws and got the window done a little bit but is still hangs up. Should I remove the other screws to losen the other track?
04-07-2019, 02:04 PM | #15 | |
You can try it but I'm not sure it will do any good to remove the wing window channel screws, it still won't move much. LockDoc
04-07-2019, 03:16 PM | #16 |
Did you remove all of the torn felt? That's where I would start - you're going to need to replace it anyway.
04-07-2019, 03:38 PM | #17 |
Ok I tryed and ya it did do no good. New question. How to get the window down the replace the regualer and the felts
04-07-2019, 03:46 PM | #18 |
This YouTube video might help
https://youtu.be/RY3yXCjqkZE
1967 C10 Step side 1970 AMX 390 1977 Datsun 280Z highly modified with '95 LT1 power |
04-07-2019, 04:49 PM | #19 |
I've seen that video before but wached it again. I think im going to order a new regular and the felts and then when I get them I will start to mess with it more. better stuck up then mess with it with out the new parts and have it stuck down.
04-07-2019, 06:01 PM | #20 |
what a coincidence, I just finished unfreezing the passenger side window on my new longhorn today..
the driver's side was tight but loosened up easily with some pb blaster and lubed with pb spray lithium grease.. the cam followers in the regulator tracks take some repeated movement but loosened up once soaked good.. the passenger's side rubber wiper lip lower down in the glass run was stiff and binding the metal glass track.. old farm truck probably didn't have passengers in it often so it was likely not used a lot over the years.. since it will later be replaced, I simply took a short putty knife and scraped the rubber lip away so the track would slide down the channel.. copious amounts of lube allows it slide easily for now good luck!
I started out with nothing - and I still have most of it |
04-07-2019, 06:57 PM | #21 |
Haha I had it freed up not to long ago. It was buttery smoth then it just locked up. All well the driver side still works good and the wing window on the passager side works
04-13-2019, 09:34 AM | #22 | |
Still plays with trucks
When you had it freed up it was shifted to the side but has now worked its way back over to where it causes the binding up problem.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
02-13-2020, 09:46 PM | #23 | |
1971 C10 127 in wheelbase Model Number-CS10934 Body Type & Seating-Fleetside 8 ft. Original Factory Price-$2,854 Shipping Weight-3,605 lbs Total Production-206,313 |
02-13-2020, 10:58 PM | #24 |
embarrassingly, my door panels are still off so I can try to remember to get pics inside there this weekend
02-14-2020, 09:08 AM | #25 | |
Plus 1 on this. My son's felt was messed up and I could not get the window up to save my life. LOL |
