![]() Join Date: Nov 2018
I played with 65 Chevy truck this weekend I have a question
Hello
I have been slowly working on my 1965 Chevy C10 truck. I managed to find a dipstick ( was missing when I bought truck I don’t know where it went) to put down into the engine today. I was happy to see black oil to full level on dipstick. I’m concerned about the black gritty stuff that was on bottom of dipstick. It’s not metal. This engine has not been touched since 1987. I would like to try and get it running again if possible. I was thinking the black gritty stuff could be deteriorating gasket or something?? What would you guys do before you started this engine? Thanks Pete Last edited by Blk63vette; 04-07-2019 at 07:26 PM. |
![]() Join Date: Jan 2003
Re: I played with 65 Chevy truck this weekend I have a question
Change the oil, prime the oil pump.
Use fresh gas, not from the tank, check coolant level, change if necessary.
1969 ![]() 1950 Chevy Wagon 1978 Big 10 1967 C10, 250,3-OTT |
![]() Join Date: Aug 2010
Grit bad, new oil good. Pull the pan.
The grit is probably carbon.
![]() Join Date: Oct 2009
Not sure what you mean by "bottom of the dipstick tube" - are you talking about where it seats in the block (i.e. grit OUTside the tube that is visible to the eye) - or are you saying there's gritty crap actually hangin on the dipstick when you pull it out and check the oil? I'm not sure how one could know there is black gritty stuff on bottom of dipstick tube (because it's down inside the oil pan) without removing the tube from the engine or having the engine apart (or using a fiber optic scope
#6 | |
![]() Quote:
The dipstick itself has black oil and some black grit on it. I’m not sure what it is...It’s not Metal shavings but it’s clumpy and hard on the dipstick when I put it all the way into the block. Weird that it’s on the bottom half of dipstick. Pete LoL I must be tired I read my post and even I was surprised,,, ![]() |
60-66 Nut
![]() ![]() Join Date: Mar 2007
I would drop the pan as suggested and get to cleaning everything. It would likely be a good idea to put a new oil pump and pickup in it since it is this far apart. Of course that is assuming that you have reason to believe that the engine will run. Also, if the cooling system has been sitting that long with coolant in it, the freeze plugs could very well be rusted through or very close to rusted through, unless they are brass.
