Old 04-08-2019, 11:54 AM   #1
Ramiro0727
Door Glass Channel Guide
My son purchased a weather-strip kit for his door windows. I don't think the weather-strip for the Door Glass Channel Guide was part of the kit he purchased. The old one we took out of the channel fit tight. There are 2 pieces on the kit he purchased that might go into the Glass Channel Guide but they fit real loose. I cant seem to find the proper one weather-strip for Glass the Channel Guide
Thanks,
Ramiro0727 is offline   Reply With Quote
Old 04-08-2019, 11:29 PM   #2
RustyPile
RustyPile's Avatar
Re: Door Glass Channel Guide
Here's a link to the complete kit for both doors..
https://www.classicparts.com/1967-72...tinfo/03-617/#
I know it has all the correct parts because I just finished the doors on my '71 with it.. If you want to replace the weather strip on the vent windows, you need a separate kit for those..
RustyPile is offline   Reply With Quote
Old 04-09-2019, 12:33 AM   #3
Ramiro0727
RustyPile,
My son purchased his kit from Precision. Here is the link:https://www.prp.com/product/detail/104074 . Attached is the felt I need for this part for the window.
Thanks,
Ramiro
Old 04-09-2019, 03:10 AM   #4
RustyPile
RustyPile's Avatar
[EDIT] See my edited post. I'm not at all familiar with precision parts, but the Classic Parts of America kit contains each and every piece that's needed to replace all channel felt, inner and outer window sweeps, everything except the rubber weather strip for the vent windows.. With the kit I used, you have to, using a very sharp razor knife, cut the old felt just inside the chrome bead in order to remove the channel felt. The felt is held in with glue.. You have to pull the old felt out, scrape out the old glue and remove any pieces of the old felt.. The replacement felt is then glued in place using a quality weather strip adhesive.. I used 3M..
Old 04-09-2019, 03:20 AM   #5
RustyPile
RustyPile's Avatar
[EDIT]
I'm sorry, I made a mistake in my previous post.. Those parts in your picture are not the division bars. They are the lower tracks that run at a slight angle down the back side of the door.. Felt strips don't fit in those tracks.. The long rubber strip that starts at the front upper corner of the door frame, continues across the top and makes that sweeping turn down the back is the weather strip that fits in those channels.. You have all the parts you need..
Do a search.. I forget the author of the thread, but there is a thread on this site that explains step by step how to remove and install all the door weather strips..
Old 04-09-2019, 02:07 PM   #6
Ramiro0727
Originally Posted by RustyPile View Post
[EDIT]
RustyPile
I was able to find that thread. I believe we have everything we need for the doors. Also was able to see a video on YouTube that showed what actually goes in to the Rear Glass Run channel. Thank you for your help.
Ramiro0727
Old 04-09-2019, 09:54 PM   #7
71gmcC15
71gmcC15's Avatar
What to post the link to the thread?
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original )
94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless
07 gmc sierra classic rcsb 4.3 lt 5 speed w/t
04 chevy Silverado 1500 ext cab 5.3 4l60e.
81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green)
71gmcC15 is offline   Reply With Quote
Old 04-10-2019, 09:59 AM   #8
Ramiro0727
71gmcC15 here is the link to the thread. http://67-72chevytrucks.com/vboard/s...p+installation. I went through every page on the thread. I believe on page 3 there is a link to a YouTube video that shows the assembly of a door.
Ramiro0727
