Old 04-08-2019, 06:59 PM   #1
Dodge68charger
Front End Suspension Shims
I Found These In My Box Of Parts. The Insides Are Grooved and Look Like They Go OnThe Upper Control Arm Bolts. 2 Are Thick. 2 Are Thin. Thanks
Dodge68charger is offline   Reply With Quote
Old 04-08-2019, 07:47 PM   #2
SeanB242
SeanB242's Avatar
Re: Front End Suspension Shims
Looks like the ones I just seen pulling the upper control arms off. Between the upper shaft and frame.
SeanB242 is offline   Reply With Quote
Old 04-08-2019, 07:59 PM   #3
Dodge68charger
Thick One Or Thin One In The Front? Thanks
Old 04-09-2019, 02:12 AM   #4
Dodge68charger
Bump
Old 04-09-2019, 12:19 PM   #5
HO455
Post Whore
HO455's Avatar
I would put the thin ones on the front to give yourself as much caster as possible. Photo from my Burban.
RIP Bob Parks.
Old 04-09-2019, 12:26 PM   #6
SeanB242
SeanB242's Avatar
I didn’t pay that much attention. I thought they was all the same. I’ll have to check when I get home
Old 04-09-2019, 01:40 PM   #7
Dodge68charger
Thank You
Old 04-09-2019, 01:49 PM   #8
67 chevelle
67 chevelle's Avatar
look like body mounts to me , a bodies have a shouldered one below and one like those above , body to frame
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 04-09-2019, 02:12 PM   #9
Dodge68charger
They’re Shims. I Remember Pulling Them Off. Ones 1/2 Thick. The Others 1/4.
Old 04-09-2019, 03:30 PM   #10
HO455
Post Whore
HO455's Avatar
The serrations on the inside of the washers certainly makes the case for them having been on the upper control arm mounts. I don't believe they were the stock washers. Here is a thread that may help. And a photo of the factory set up.
I installed thick washers like yours on my lowered Burban to keep from having 8-10 shims.
http://67-72chevytrucks.com/vboard/s...d.php?t=589541
RIP Bob Parks.
