Old 04-08-2019, 09:50 PM   #1
Fatherof3
Fatherof3's Avatar
Can I use 72 C10 front suspension on a C20?
I have searched and seen lots on C20 to front 5 lug disc C10 conversions and they never say you can use 1971/2 C10 parts. I'm asking because a I have a 65 C20 and a 72 C10 donor. Thanks
65 C20 292 4spd 4:56 Eaton HO52
Fatherof3 is offline   Reply With Quote
Old 04-09-2019, 12:09 AM   #2
Captainfab
60-66 Nut
Re: Can I use 72 C10 front suspension on a C20?
On the '63-'66 C20's you will have to change the entire suspension including the crossmember with that from a '71-'87 C10. You do NOT have to use only '71-'72 parts. If that is what you already have, then by all means use it.
Old 04-09-2019, 10:01 AM   #3
Fatherof3
Fatherof3's Avatar
There are several posts that use the just the C10 LCA, spindle and tie rod to do this. But they never say to use 71 and 72 C10 parts. Is there a difference that would keep this from working?
Old 04-09-2019, 12:05 PM   #4
Chevy Fleetside
Chevy Fleetside's Avatar
You have to use the entire cross member. The lower control arms mount differently on the C20. You will need all of the steering components.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 04-09-2019, 01:19 PM   #5
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Roll the old out, and roll the new in.
Do the whole crossmember and all.
66 C20 Service Truck:
Old 04-10-2019, 12:49 AM   #6
Captainfab
60-66 Nut
The difference is that you are converting a '63-'66 C20 to a C10. A C10 lower ball joint will be too small for a '63-'66 C20 lower control arm, and on the '63-'66 C20's you can not just change the lower control arms for those from a C10. The '63-'66 C20's have a flat lower control arm shaft with no saddle which is necessary to hold a round C10 lower control arm shaft. That is why you have to change the entire crossmember. If you were starting with a C10, it would be simple and easy.
Old 04-10-2019, 12:03 PM   #7
Fatherof3
Fatherof3's Avatar
Thank you Captianfab!
This is exactly what I have been trying to understand
