Auxiliary battery boxes
Anybody have a pic of a oem setup with 2 batteries?
What goes where and did they move anothing around?
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
Re: Auxiliary battery boxes
The washer jug gets removed and replaced with a little different style to the opposite side. If I Recall Correctly.
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
![]() Join Date: Oct 2011
Someone will probably post up a few pics...and there are a couple of minor things.
One thing is that the regulator (if you still have one) gets moved from the rad support onto the new battery box....which is pretty easy to do. Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
I have a radical idea!
I just added one on my diesel dually, but I do not have a voltage regulator or the washer fluid bottle.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
Here is a couple of pics I dug up this weekend when I installed mine. My ‘67 radiator support didn’t have most of the holes, so I had to drill 3 holes to mount it.
One with what was said to be factory wiring. I’m not doing that on mine. I’m going to run a large battery cable to the positive side and probably run the ground down to the frame on mine.
This was said to be out of a low mileage survivor truck.
![]() Join Date: May 2010
I don't have one, and I'm obviously no expert. However, here are 4 threads that may help.
http://67-72chevytrucks.com/vboard/s...d.php?t=488347 http://67-72chevytrucks.com/vboard/s...d.php?t=419842 http://67-72chevytrucks.com/vboard/s...d.php?t=219380 http://67-72chevytrucks.com/vboard/s...d.php?t=195732 |
Awesome thanks. Passenger side washer tanks must be rare as the white moose
I’ve never seen one, but knowing GM, it could very well be from a Buick, Olds, Pontiac, Cadillac? that has a driver’s side starter.
I've got a number of threads on this as I tried to get it "right" down to the correct reproduction batteries on each side, as my truck had both DUAL and HDBAT options, so had to figure out what that got you...
I've got a number of teardown pics of my original, so if you need info, let me know and I'll see what I can do!
Is the passenger side jug different or just moved.
Pic of the mount would be great |
#13 |
I have a washer tank on the passenger's side. Currently using it as a coolant overflow.
Not sure if it was factory or not. My truck did come with factory dual batteries. I don't have a drivers side tray, and the regulator was mounted to the firewall. When I got the truck, the second battery was in the bed. I found the original dual battery wiring (relay that hooks into IGN UNFUSED) in a box of stuff I removed with the bed battery.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
