![]() Join Date: Jun 2017
BIG BLOCK valve train
if you put a roller cam ,lifters,and roller rocker arms do you use different push rods or stock push rods need a little refresher course thanks
Re: BIG BLOCK valve train
I know a sb has shorter rods. The lifters are taller. Would assume the same on a bb.
I have a radical idea!
You would need shorter pushrods if they are hydraulic roller lifters. Solid roller lifters are usually the same height as flat tappet lifters.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
Moderator
Try and by the entire it from same supplier....
Pushrod lengths vary from manufacturer to manufacturer.... BEWARE..... Make absolutely sure the lifter sets go in the correct way....I have had several "professional builders" install big block roller lifters oriented the wrong way...really quick death to both lifter and cam....makes a huge metal dust mess... ![]() ![]() ![]()
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox ![]() ![]() ![]() |
#5 | |
I put the Comp SK kit in my 427. Some report the Comp lifters are not the best, but I guess I'll find out...
