![]() Join Date: Dec 2018
Pittsburgh 2T Engine Stand
Bought this used and have a 350 bolted t it. Problem is that if I take it off my hoist the engine tip's down so much I am uncomfortable unchaining it. I have even tried reversing the main load bearing center support because it looks like it leans forward somewhat when empty. Holes for bolts do not line up when trying to turn support around. Using 3" bolts for mounting engine. Probably going to build a wood front brace for extra support but just frustrated -----
Moderator
![]() Join Date: Jun 2017
Re: Pittsburgh 2T Engine Stand
Most likely the head tube is not welded on correctly....
I tried two a while back, one had your issue, the other had really bad welds... I got a refund and bought a Strongway from Northern Tool.... Handles anything I build....SBC, BBC, LS....even ahd a BB Chrysler on it...no problems... https://www.northerntool.com/shop/to...SABEgJV2vD_BwE
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox ![]() ![]() ![]() |
I have a radical idea!
Good ol’ Horror Fright “Pittsburgh” stuff. Apparently there is a Pittsburgh in Chinaland...
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
The one ton harbor freight stand is badass. I've had both my 427's on it and no goofy flex. The 1/2 ton stand, well that's a different story.
