Old 04-11-2019, 10:07 AM   #1
ohboy321
ohboy321's Avatar
WTB -67/68 K10 Left Side Ram Horn Exhaust Manifold
I am looking for a 67/68 K10 Left Side Ram Horn Exhaust Manifold. This would have a strait center dump, with the alternator mounting bosses/holes facing the front like the picture below.
(note - One in pic is from a Vette. They look similar, but have different casting no's)
ohboy321 is offline   Reply With Quote
Old 04-11-2019, 04:48 PM   #2
Ironhorse
Ironhorse's Avatar
Re: WTB -67/68 K10 Left Side Ram Horn Exhaust Manifold
Have one VERY similar to that manifold but has the AIR (Air Injection Reactor) tubes or more commonly referred to as SMOG tubes. Appears to be in good shape with no cracks I can see. Not the same but would work by plugging the AIR ports. Let me know if at all interested
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 04-11-2019, 06:27 PM   #3
ohboy321
ohboy321's Avatar
Thanks, but I would prefer one without the tubes.
Old 04-11-2019, 06:57 PM   #4
Ironhorse
Ironhorse's Avatar
Understand, not a problem. Just throwing that manifold out there since have had no other responses. Good luck in your search.
Wellington, Ks
Old 04-11-2019, 10:18 PM   #5
72chevynut
72chevynut's Avatar
I believe I may have one. I’ll check tomorrow and get back with you.
Michael
72chevynut is offline   Reply With Quote
Old 04-11-2019, 11:39 PM   #6
projectking
projectking's Avatar
I have one and need one for a 2wd if you have one to trade?
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 04-12-2019, 03:42 AM   #7
ohboy321
ohboy321's Avatar
The one I have is an earlier version with the alternator mounting holes facing the side. Most of the mount was chopped off to accommodate the home had alternator bracket.
Old 04-12-2019, 06:23 AM   #8
projectking
Bummer!
67 Chevy C10 LWB
90 Mustang Gt
Old 04-12-2019, 08:30 AM   #9
painterljp
I have some. Believe to be correct. Dont know about numbers on them but I gots one.
painterljp is offline   Reply With Quote
Old 04-12-2019, 10:59 AM   #10
ohboy321
ohboy321's Avatar
Do you know what those came out of? I have seen those casting numbers listed for early 250 and 300HP 327's with 2" output on the left side and 1.9" (heat riser) on the right. I have a 220HP 327 with what appear to be similar outputs.
If they would be bolt in replacements for my K10 I may consider the pair.
Below is a picture of the left side 2" output I have now for comparison. I'll post a pic of the right/heat riser side later.
Old 04-12-2019, 02:27 PM   #11
painterljp
They should be bolt on replacements.. will measure and get back with you tonight I get off work at 630-7pm. Will check then. Also have a lot of people to answer about other items on here. Thanks.
Old 04-12-2019, 03:42 PM   #12
72chevynut
72chevynut's Avatar
I checked mine, sorry no match to what you want. Here are pics of what I have.
Michael
Old 04-12-2019, 05:47 PM   #13
ohboy321
ohboy321's Avatar
Thanks. The one I have now used to look like the one in your top picture, until someone chopped off the alternator mount.
Old 04-12-2019, 06:11 PM   #14
ohboy321
ohboy321's Avatar
Here is a picture of my right side output. If the output measurements for both match what I have then I would be interested to know what the price for the pair would be shipped to 03046.
Thanks!
Old 04-12-2019, 08:51 PM   #15
painterljp
Here's pics of measurements. Started at 1 " cause my tape has an end on it.
First pic drivers side with alternator horn.
Old 04-12-2019, 09:31 PM   #16
painterljp
You do shipping quote my zip is 87107. Hell I am coming up with like 88$$. That ain't a gonna work. Am sure for you neither.
Old 04-13-2019, 08:43 AM   #17
ohboy321
ohboy321's Avatar
Using the pair I have for an example I came up with $80-$90 to ship, so your number isn't unexpected. That is the reality of shipping larger heavier packages cross country. Even with the cost to ship I still want them, so lets work out a price for the pair.
Old 04-13-2019, 09:03 AM   #18
painterljp
How about 80. For pair plus shipping of course. I wonder if it would be cheaper to box them separately? Let me know. Thanks. Just checked fed ex. Their quote was about 60. But that is guestament.
Old 04-13-2019, 12:16 PM   #19
ohboy321
ohboy321's Avatar
$80 for the pair plus shipping is good and I will buy them.
I looked at the cost for shipping separately and the lighter of the 2 was $50 alone, so together works out the cheapest.
I'll PM the shipping details.
Thanks!
Old 04-13-2019, 02:41 PM   #20
painterljp
Sending pm. Thank you.
