Old 04-11-2019, 08:10 PM   #1
bigmoe
bigmoe's Avatar
Brake switch for Gen IV LMG 5.3
My swap is using a 2008 5.3 from a Tahoe. I've read some posts about using a 4 connector brake light switch (needing 12v normally on and off when brakes applied) for Gen III swaps. Is this going to be the same for the Gen IV?
bigmoe is offline   Reply With Quote
Old 04-11-2019, 09:43 PM   #2
ls1nova71
ls1nova71's Avatar
Re: Brake switch for Gen IV LMG 5.3
No. For a GenIV swap you just use the original switch and hook one wire to the cold side of the switch so the ECM sees 12v when the brakes are depressed.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 04-11-2019, 10:30 PM   #3
bigmoe
bigmoe's Avatar
Cool. Good to know. Thanks.
Old 04-13-2019, 04:58 PM   #4
First c10
First c10's Avatar
Ok so I read this thread and decided to check.
I have a 2008 gen IV 4.8/4L60E.
I have my brake wire Connected to 12volts until the brake is pressed. I am using the gm cruise style brake switch. I check with my scanner and it is correct so for fun I connected it like above ls1nova71 indicated. It read brake pedal “yes” when the brake was not pressed.
We want the scanner to show “no” when pedal not pressed and “yes” when pedal pressed correct?
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 04-13-2019, 05:21 PM   #5
ls1nova71
ls1nova71's Avatar
Gen IVs are backward of GenIIIs so you shouldn't need that switch. Is it working right connected that way? I wouldn't think it would work? Also, what kind of scanner are you using? Usually they will say "applied" and "released" for brake pedal input.
Old 04-13-2019, 06:44 PM   #6
First c10
First c10's Avatar
I am using hptuners and logging brake pedal applied yes /no
GO GO!!!
Old 04-13-2019, 06:52 PM   #7
First c10
First c10's Avatar
Would this matter if I didn’t have actual taillights in the truck yet?
Hell the truck doesn’t have any exterior lights.
GO GO!!!
Old 04-15-2019, 09:53 AM   #8
solidaxel
solidaxel's Avatar
Following!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 04-17-2019, 12:06 AM   #9
ls1nova71
ls1nova71's Avatar
I just looked at the schematic for a 2012 Tahoe, and it does show a couple of wires that could go to the brake switch like you seem to have, but I don't think they are necessary in a swap. Do you have the NC set of contacts wired to X3 pins 12 and 13? Pretty sure the only one you need on a GenIV is X5 pin 6 (light blue) which needs 12 when the brakes are applied.
Old 04-17-2019, 12:16 AM   #10
First c10
First c10's Avatar
This is how I wired my swap
http://lt1swap.com/E38%20ECM%20Connector%20Pinouts.htm
It shows J1 of X1 pin 9. It’s reads “12v+ hot with brakes applied. Open when NOT on the brakes.”
But that contradicts what HP tuners shows when I tested it. I am a little confused.
GO GO!!!
Old 04-17-2019, 06:39 PM   #11
sprint_9
sprint_9's Avatar
This is incorrect.
You need to run everything on the Normally Open side of the switch, so you only get 12v when the brake is pressed.
I assume in your picture that the light blue wire by itself is the one going to the ecm, if so that needs to get tied into the other wires on the other side of the switch.
sprint_9 is offline   Reply With Quote
Old 04-17-2019, 08:34 PM   #12
First c10
First c10's Avatar
Originally Posted by sprint_9 View Post
This is incorrect.
I agree but when scanning the brake pedal applied yes or no
Wired this way in the picture scans correctly.
That’s the reason for my posts.
I am going to check it with the brake lights actually installed down the road.
GO GO!!!
Old 05-22-2019, 10:43 AM   #13
First c10
First c10's Avatar
Hey guys,
I was able to get to the point of starting the truck and putting it into gear while up on jack stands. While I was checking my rear brakes. I put the truck in drive and while idling I stepped on the brake pretty firm and the engine almost died like the converter was locked.
I tried a few times and it feels like the converter is definitely staying locked. The first thing I thought of was this tread.
I did wire it the way everyone said it should be, it is getting 12v when brakes are applied.
What to check or do????
GO GO!!!
Old 05-22-2019, 11:32 AM   #14
ls1nova71
ls1nova71's Avatar
You can kind of disregard what I said in post 9, my dumb ass was looking at BCM connectors, so sorry about that. I checked it again, and it definitely shows the ECM needing power at X1 pin 9 when the brakes are applied. Not sure why your HPTuners is showing the brake on/off signal backwards though. Have you tried actually hooking up the brake lights to see if that changes anything? Also, what pins do you have the other wires on the brake switch hooked up to?
Old 05-22-2019, 12:15 PM   #15
First c10
First c10's Avatar
X1 pin 9 0.5 L-BU/WH 6311 Brake Switch Signal (goes to underhood fuse block P3, wire also goes to TCM, both hook to tcc brake switch at brake pedal, 12v+ hot with brakes applied. Open when NOT on the brakes.)
and 6311 0.5 L-BU/WH to TCM plug.
I do not have any brake lights connected. I will have to wire in a light bulb and see if that works.
I currently have the stock brake switch installed and wired like:
Orange 12v one side of switch
Other side of switch=
White- Brake light feed
Brown- to remote start brake pedal signal
Blue- to PCM/TCM brake light trigger pin 9
GO GO!!!
