04-13-2019, 09:22 PM | #1 |
Fuel tank mounting straps
Gone!!!
From a 72 burb, unsure of the blazer/suburban interchange. I can say the actual flat strap part is 38.5” long. Comes as you see, two straps, only one pad, the j-bolts, and rectangle washers are included. $70 shipped in the lower 48 states
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com Last edited by Madkidd007; 04-19-2020 at 08:00 PM. |
05-02-2019, 07:56 PM | #2 |
Re: Fuel tank mounting straps
Ttt
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
09-02-2019, 04:51 PM | #3 |
$55 shipped
10-19-2019, 12:14 PM | #4 |
And $50 shipped.
04-19-2020, 12:36 PM | #5 |
Good morning,
Do you still have this? I’m interested in getting some OEM fuel tank straps to replace mine that have been bent up from past off roading. I was thinking that Suburbans and Blazer used the same tank but I’m coming up with different dimensions than you are describing. Can you confirm from where to where you are measuring, please. Because of the shape, maybe using a string to contour to shape and then lay string flat to measure? I could do the same and we can confirm if this will work for my 72 Blazer. |
04-19-2020, 07:59 PM | #6 | |
04-19-2020, 09:36 PM | #7 |
Thank you. I’ll keep looking.
