Do I need hi temp paint for my air cleaner?
I have a 1972 GMC Longhorn with 402ci big block recently purchased. The air cleaner housing and cover could use a fresh coat of paint to spruce up the engine bay. Am I better off with high temp paint? Just checking so I don't have to paint twice. Thanks for any input
Re: Do I need hi temp paint for my air cleaner?
Nope.
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
I actually painted mine with Rustolium dark grey textured paint and it looks pretty good.
You don't need high temp paint for the air cleaner.
But highly recommend that you use an engine paint. Engine paints are formulated to be more resilient in the engine compartment including being resistance to gas, oil and chemicals. I actually just researched, because I am putting an OEM/original air cleaner back on my 1972 GMC Jimmy. I had a cheap aftermarket chrome one that is rusting. Bought an original one and just had it blasted. Under the engine paint I will be using a high zinc primer for corrosion resistance. I am new to the forum, but I am a mechanical engineer who worked for John Deere, Mercury Marine and Tracker boats. I worked closely with paint engineers. Our own plus those at suppliers. Terry |
I use vht roll bar and chassis paint. Its semi gloss, but it's durable.
2003 Dodge 2500 1969 C10 2014 Camaro SS/RS/1LE |
Where's my beer?
No. I used Krylon Gloss black on my valve covers on my Corvette, not high temp, and it has held up perfectly for more than 10 years.
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
Thank you all for sharing your experiences, saves time! Love this site!
You can use plain old rustoleum, no engine paint needed. My father did his air cleaner on his 70 impala 22 years ago and still looks new.
#9 | |
![]() Join Date: Feb 2009
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
I used VHT engine matte black. The finish is more like satin and looks factory.
Sloonz,
Where did you buy the VHT engine black matte/ Thanks, Terry |
#13 |
Just a FYI but I used dupli color engine enamel from advance auto on my valve cover, intake and exhaust manifolds. I was told that 292 runs really hot... burned off on the exhaust manifold within a day or two but the rest seems unphased. I used the chevy orange and the clear. Looks pretty good for spray bomb.
#14 | |
#15 | |
Any decent enamel should work fine for you. If you go with VHT dont use their epoxy paint line. It is not a true epoxy paint and has zero resistance to some chemicals and is not very durable. |
#16 |
I used NAPA chassis black paint on my air cleaner and inner fenders, its a nice satin black.
#17 |
Because of sloonz post I checked out the VHT engine paint.
I went to Oreilleys and Autozone. I ended up buying the GM black satin engine paint at Autozone. Oreilleys had VHT, but not the GM satin black. It was $8.99 a spray can. Engine paint so will resist oil, gas chemicals. Plus heat resistant. This what I will now use. Will also use it for original valve covers I am putting on Jimmy. Currently has some cheap chrome covers that are rusting. Poor chrome job, and they are Edelbrock! Going black, not the Chevrolet orange since it is a GMC. Returning other black gloss engine paint I had already purchased. This is not just a satin, but specifically the black satin that is the GM black for the engine area. I really liked the idea that was posted in the thread of repainting it with the original black satin so I revisited the gloss black I had already purchased Thanks everyone!!! The forum comes through again for me. I love the forum. So glad I joined it a month ago. Terry |
#18 | |
Terry, I originally painted my air cleaner with the satin and it was a little to glossy for me so that's why I ended up using the matte. Let us know how it turns out!
