Old 04-14-2019, 06:57 PM   #1
Angrywood
62 turn signal switch return/cancel
On my 62, when i Put the turn signal switch up to signal right and i turn, the knob drops back into place but the right turn light keeps flashing. I have to drop it down to signal left before it cancels the right turn light. The left works just fine. Is it the switch mechanism in the steering wheel or something else? The switch that is located at the bottom of the steering wheel under the dash was recently replaced.
Angrywood is offline   Reply With Quote
Old 04-14-2019, 08:51 PM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: 62 turn signal switch return/cancel
Canceling cam possibly with the turn signal switch is my thought
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-15-2019, 01:12 AM   #3
Angrywood
What’s the canceling cam ?
Old 04-15-2019, 07:37 PM   #4
Clyde65
Clyde65's Avatar
The part of the switch that actually flips the lever back to Center when you start straightening out the turn...
Clyde65
Rebuild of Clyde
support our troops!
Old 04-15-2019, 07:39 PM   #5
Clyde65
Clyde65's Avatar
I may be speaking out of turn. I’m used to 64-66, here is a replacement switch
https://www.tuckersparts.com/Turn-Si...-CTS-6062.html
Clyde65
Rebuild of Clyde
support our troops!
Old 04-16-2019, 09:53 AM   #6
bhap
bhap's Avatar
Take a look at the hub that holds the turn signal lever. On mine the hub would rotate and the cancel cams would get off center and do what you are describing - stay on in one direction and only cancel if you pull lever all the way in other direction. I centered the hub and tightened the three screws that hold it in place. The other thing you can check is that the bowden cable is secured to the column so it doesn't flex when you turn the signals on and off. I put a couple of cable ties on mine and it has been working pretty good.
bhap is offline   Reply With Quote
Old 04-17-2019, 06:11 PM   #7
Angrywood
Thanks. I’ll check that out
Old 04-17-2019, 06:44 PM   #8
demian5
demian5's Avatar
60 is way goofy. Good luck.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 04-21-2019, 10:55 AM   #9
62 Barnfind
62 Barnfind's Avatar
I was having the same problems with my 62. I never could get it to work right so I finally broke down and bought a I did it column.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 12-02-2023, 11:41 PM   #10
62bagger
62bagger's Avatar
I am having the same problem with the signals on my 62. Is there a certain position for the cancel cam? I think I have all the pieces just not in the correct order.
62bagger is offline   Reply With Quote
Old 12-05-2023, 11:20 AM   #11
bhap
bhap's Avatar
It has been a while since I fixed mine, but I think the screw that holds the turn signal lever should be centered in the hole when the signal is off. I would loosen the cable at the bottom of the steering column - which is where the electric happens - and the adjust the cancel mechanism and column housing so that it lines up the screw with the opening for the lever when the detents are in the middle. Tighten up the top then go to cable and switch at bottom of column. Put switch in center position and tighten. As long as you have the springs in place and the cable/stiff wire is free to move along the column, it should work. I think I added a couple of cable ties along the wire so it didn’t flex when the signal was activated.
