Upper Control Arm Bolts?
I Got a 6 Inch Drop In The Front.. Anyone Make Their Own Spacers Instead Of Using a Bunch Of The ‘Y’ Shaped Shims To Get The Alignment Close..
Also One Bolt Has A Slight Wobble In It, Its Brand New.. Will It Be Okay Once Its Tight? Thanks Posted via Mobile Device |
Re: Upper Control Arm Bolts?
![]() https://www.rockauto.com/en/moreinfo...030217&jsn=444 I used the offset arm shaft when I rebuilt mine, It isn't much but I didn't have to use as many spacers as before. Got mine from RockAuto. Last edited by Breeze454; 04-16-2019 at 11:34 AM. Reason: Added pic & web address |
Performanceonline actually sells a kit of alignment spacers that are pretty nice but kind of expensive. I am using them on my truck.
https://www.performanceonline.com/19...-Control-Arms/ |
Can I Make My Own Just Cutting Solid 1 1/2 Round Bar Of Different Thicknesses and Drilling 1/2 inch Holes In Them?
I'm guessing this is a no-go, but could standard washers be used? I suppose it would be a huge hassle to remove the control arm over and over to get the adjustment dialed in for this idea.
Even Something To Get Me In The Ball Park So I Dont Gotta Add So Many Shims
Gonna Try n Make These
